Using Opto Isolators — Parallax Forums
edited 2003-03-08 21:22 in General Discussion
I am building a large dc motor driver(still). I am using a PAK-V to
drive very large MOSFETs(100v 180amp rating, I'll be using 15vdc to
drive) and relays(12v 40amp). I would like to use a couple of Opto 22
modules that I have laying around. In the data sheet for the ODC5, it
shows using a N channel transistor. Has anyone used one of these
modules? Can I simplify and just send the positive signal? I would
assume that if i can, I can also use the same technique for the
Stamp's I/O's(switches,indicators,etc). Thanks.
Ian
    edited 2003-03-08 21:10
    Hi Ian,
    I haven't used the Opto modules in a while, but a Web search looks like
    they draw 18mA max from the control input and need at least 3.7V. The
    Stamp and the PAK both can drive 18mA, but maybe not all at one time.
    Both chips have a maximum current rating for the total. So for the PAK,
    you can have about 130mA passing through the chip. The chip itself draws
    80mA or so. So that gives you about 40 or 50mA to play with. If you are
    drawing 18mA per pin, then two or three pins would put you right at the
    limit and you probably want some safety margin. On the other hand, our
    ratings are relatively conservative and your duty cycle will be less
    than 100%, but you still don't want to push the envelope too hard.
    The Stamp has a similar specs, so while you might be able to draw 30mA
    through each pin, you have a limit of 60mA total or some such.
    I wonder if the opto draws much current when off (I can't imagine it
    does, but that would be easy to test with a ammeter). If so, maybe you
    could use a pull up resistor to supply the on current and then just
    switch the Stamp output to ground or an input. That wouldn't help with a
    PAK-V though.
    Hope that helps.
    Al Williams
    AWC
    * NEW: New kits!
    http://www.al-williams.com/kits.htm
    > From: iphillipsca [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=meNx-yw3G67mfmLNxlpwDncT2XXItt7YRAvlX_PlJOddcngwjH9s1cWWRD_foIY6aC7eGgM5GINEaz1pW-cI4gg]iphillips@s...[/url
    > Sent: Saturday, March 08, 2003 2:35 PM
    > Subject: [noparse][[/noparse]basicstamps] Using Opto Isolators
    > Ian
    > from the same email address that you subscribed. Text in the
    Hey Al! Thanks for the reply. So using a small N channel for the
    negative side of the Opto would probably be the best idea then. I've
    got a couple of IRL540n's left that I can use. Thanks again.
    Ian.
    --- In basicstamps@yahoogroups.com, "Al Williams" <alw@a...> wrote:
    > Hi Ian,
    like
    The
    time.
    PAK,
    draws
    are
    the
    our
    30mA
    you
    with a
    > PAK-V though.
    > Hope that helps.
    > Al Williams
    > AWC
    > * NEW: New kits!
