Semi-OT - servomotor circuit
I've just had the opportunity to recover some Honeywell modulating
motors that are not operational. After examining them I've determined
that the fault is thier position feedback gizmo. What they use is two
semi-circles of (apparently) painted on resistive material around the
shaft and a couple copper arms that slide over them. Basically just a
big variable resistor. The resistive material has worn through to the
PCB underneath so the feedback is no longer operational.
Would anyone happen to know if I can purchase a paint-on resistive
material at all? I can use an ohmmeter to find out the ohms per inch
or whatever.
If I get these functional I can have some great fun interfacing them.
At 80lbs torque they'd be capable of some real work. I'd just have to
cook something up!
or whatever.
cook something up!
for defrosters could work. You 'paint' this stuff on,
and then heat it with a heat gun (I think 800 degrees)
to cure it. If the disk will take the heat, this
could work. My Honda dealer had the stuff for
repairing rear window defrosters.
--- In basicstamps@yahoogroups.com, "ghidera2000" <ghidera2000@y...>
determined
two
the
a
the
inch
> or whatever.
them.
to
> cook something up!
just about any surface... I do not know if it would hold up in your
situation, but it might be worth a look....
A quick google search game me a couple of links:
http://www.contacteast.com/product/prodpage.cfm?grp=4088BDCD-EEE0-11D4-8
A710050DA5FEB55
http://www.circuitspecialists.com/level.itml/icOid/823
--Aaron
Original Message
From: ghidera2000 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Tl-YdPrKif2ctvw4PB6ewfkkUHy67jWNbJq2b7R_r15ZEVYnp1mJS0wNtBsdhlLWSnj0ud_T1Sr8x4sWKw]ghidera2000@y...[/url
Sent: Friday, March 07, 2003 6:01 AM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Semi-OT - servomotor circuit
or whatever.
cook something up!
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
they use to repair rear window defrosters it comes
in a little bottle like nail polish it's a type of
conductive ink with some resitence in it you would
have to experiment i have heard of people reparing
potentiometers with it [noparse]:)[/noparse]
--- Aaron Bond <abond@q...> wrote:
> Years ago I purchased a pen that one used to write
> circuit traces onto
> hold up in your
> A710050DA5FEB55
> --Aaron
Original Message
> From: ghidera2000 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=RTEpEC2uPPrju5P4O_5Bbd0XWs9g-mwG65wXj0eD-KCQBJmJFM0EWnqOSRba6JIfbhPXnRKm9YVpuK6mglLa]ghidera2000@y...[/url
> material around the
> Basically just a
> worn through to the
> operational.
> paint-on resistive
> the ohms per inch
> or whatever.
> interfacing them.
> I'd just have to
> cook something up!
> Text in the Subject
> Text in the Subject and Body of the message will be
> ignored.
__________________________________________________
Do you Yahoo!?
Yahoo! Tax Center - forms, calculators, tips, more
http://taxes.yahoo.com/
