Semi-OT - servomotor circuit — Parallax Forums
edited 2003-03-07 15:53 in General Discussion
I've just had the opportunity to recover some Honeywell modulating
motors that are not operational. After examining them I've determined
that the fault is thier position feedback gizmo. What they use is two
semi-circles of (apparently) painted on resistive material around the
shaft and a couple copper arms that slide over them. Basically just a
big variable resistor. The resistive material has worn through to the
PCB underneath so the feedback is no longer operational.
Would anyone happen to know if I can purchase a paint-on resistive
material at all? I can use an ohmmeter to find out the ohms per inch
or whatever.
If I get these functional I can have some great fun interfacing them.
At 80lbs torque they'd be capable of some real work. I'd just have to
cook something up!
    edited 2003-03-07 14:56
    Possibly the resistive paint used in car rear windows
    for defrosters could work. You 'paint' this stuff on,
    and then heat it with a heat gun (I think 800 degrees)
    to cure it. If the disk will take the heat, this
    could work. My Honda dealer had the stuff for
    repairing rear window defrosters.
    --- In basicstamps@yahoogroups.com, "ghidera2000" <ghidera2000@y...>
    determined
    two
    the
    a
    the
    inch
    > or whatever.
    them.
    to
    > cook something up!
    edited 2003-03-07 15:06
    Years ago I purchased a pen that one used to write circuit traces onto
    just about any surface... I do not know if it would hold up in your
    situation, but it might be worth a look....
    A quick google search game me a couple of links:
    http://www.contacteast.com/product/prodpage.cfm?grp=4088BDCD-EEE0-11D4-8
    A710050DA5FEB55
    http://www.circuitspecialists.com/level.itml/icOid/823
    --Aaron
    From: ghidera2000 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Tl-YdPrKif2ctvw4PB6ewfkkUHy67jWNbJq2b7R_r15ZEVYnp1mJS0wNtBsdhlLWSnj0ud_T1Sr8x4sWKw]ghidera2000@y...[/url
    Sent: Friday, March 07, 2003 6:01 AM
    Subject: [noparse][[/noparse]basicstamps] Semi-OT - servomotor circuit
    or whatever.
    cook something up!
    Your use of Yahoo! Groups is subject to
    you might go to a auto store and check out the stuff
    they use to repair rear window defrosters it comes
    in a little bottle like nail polish it's a type of
    conductive ink with some resitence in it you would
    have to experiment i have heard of people reparing
    potentiometers with it [noparse]:)[/noparse]
    > circuit traces onto
    > hold up in your
    > A710050DA5FEB55
    > --Aaron
    > From: ghidera2000 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=RTEpEC2uPPrju5P4O_5Bbd0XWs9g-mwG65wXj0eD-KCQBJmJFM0EWnqOSRba6JIfbhPXnRKm9YVpuK6mglLa]ghidera2000@y...[/url
    > material around the
    > Basically just a
    > worn through to the
    > operational.
    > paint-on resistive
    > the ohms per inch
    > or whatever.
    > interfacing them.
    > I'd just have to
    > cook something up!
    > Text in the Subject
    > Text in the Subject and Body of the message will be
    > ignored.
    __________________________________________________
    Do you Yahoo!?
    Yahoo! Tax Center - forms, calculators, tips, more
    http://taxes.yahoo.com/
