BS2 phone dialer?
Please help..... I'm trying to monitor an input with the BS2, if the
input doesn't fit within a limit I want the BS2 to call an leave a
numerical page...... can it be done without a 3rd party dialer?
thanks much!!
thanks much!!
connect a stamp to a phone line and dial out. Any device attached to a
phone line must be tested and then certified by the FCC. Interfacing to a
phone line has several safety implications and all must be considered.
Also, remember, you are dealing with normal voltages up to 60 volts and ring
voltages over 110 volts ac so your device must be isolated to prevent
damage.
Jim
Original Message
From: rtommy2k [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=vzg6ijFtyNeURl7IDbo44Ckzy3RtJ6X1hdNAT7y3oAoXcQmAuKoKvSJ0abn1OHqLBUWStGKJ916mky-Whw]rtommy2k@y...[/url
Sent: Tuesday, March 04, 2003 5:23 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] BS2 phone dialer?
thanks much!!
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
$120.00. On the other hand, you SHOULD be able to us any
off the shelf Modem which speaks Hayes 'ATDT' with only
serial (RS-232) interfacing.
Send ATDT 555-1212;
Wait a little...
Send ATDT 999-9999#;
wait a little...
Send ATH0
Translation: The first ATDT dials the pager service.
(the semicolon tells the modem to stay in command
mode, so you can send more numbers)
Wait a little for them to pick up.
The second ATDT sends the pager number to be sent.
Wait a little for them to acknowledge.
ATH0 hangs up the modem.
the
> thanks much!!
