Tone input
Hello All,
I cooked my first stamp and need some help as their expensive :-)
I want to use a tone around 2000 Hz picked by a microphone to turn a stamp
input to "0". If some one give me a little help I would be thankful. I'm
using a BOE with a BS2.
capacitor (simple half wave rectifier). Use a 5.1 V zener diode to
ensure that the input stays inside the 0.5-V and 5.1V positive limits
which keeps TTL circuitry happy in life. I've done this before and it
works well. Though admitadly not all in the same circuit at the same
time.<G> I also have a BOE.
Original Message
From: Bob Phillips [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Etozwia8HBPkfvEWOWnIJweM25z68iQBP10FgA0xEI4ebf0Js4mYvtQ7h0WtUq__qTgfpBsN33LD]robertp@v...[/url
Sent: Monday, March 03, 2003 11:03 AM
To: basicstamps@yahoogroups.com
Subject: Re: [noparse][[/noparse]basicstamps] Tone input
Hello All,
stamp input to "0". If some one give me a little help I would be
thankful. I'm using a BOE with a BS2.
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
Thanks for the input, (no pun).
Why charge a capacitor ?? Other wise I'm with you.
Bob Phillips
> [noparse][[/noparse]Original Message]
> From: Grover Richardson <grover.richardson@g...>
> To: <basicstamps@yahoogroups.com>
> Date: 3/3/2003 1:05:35 PM
> Subject: RE: [noparse][[/noparse]basicstamps] Tone input
> Amplify the tone with an op amp. Then use a diode rectifier to charge a
Original Message
> From: Bob Phillips [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=63diPbsVh-_vc67sbem8cbeNHBThSvkJNgKlxL-B81e1mWIhyeJeYM_f8DpcrjDXmy40nJdWAg]robertp@v...[/url
> Hello All,
> Thanks
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
current from the rectifier.
Bill
--- In basicstamps@yahoogroups.com, "Bob Phillips" <robertp@v...>
wrote:
> Grover,
> Bob Phillips
charge a
to
limits
and it
same
Original Message
> > From: Bob Phillips [noparse][[/noparse]mailto:robertp@v...]
> > Hello All,
turn a
be
> > Thanks
Subject
Subject and
>Hello All,
Do a search for NE567 or XR567
These are nice little 8 pin tone decoders that work very well. I've used
thousands of them over the years.
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 19 years of Engineering Innovation (1984 - 2003)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
If the signal is just amplified, then squared, it is possible that the
signal may be missed off and on due to the possibility that the signal
may not be the desired level at the pin when the program is looking at
the pin.
One of the other fellas did mention a tone decoder. A more elegant
method of doing things, but also very effective. There's more than one
way to work out a solution many times<G>.
Original Message
From: billakay <billak@f...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=YXx1S1X0plZm1ZgquzQYyHpBTZZe2vfXWnQHZU6vVn0-zCtqu0SAf9PCeucvH2y89K8Dtso]billak@f...[/url
Sent: Monday, March 03, 2003 1:57 PM
Subject: [noparse][[/noparse]basicstamps] Re: Tone input
I think the capacitor acts as a filter to further smooth out the
Bill
wrote:
> Grover,
> Bob Phillips
charge a
to
limits
and it
same
Original Message
> > Hello All,
turn a
be
> > Thanks
Subject
Subject and
Whats the best op amp and configuration to use to amplifier the tone ?
My input is .1 mVolts from the microphone. (2000 HZ)
I have tried a 741 with little sucess, I would like to use a 12 volt dc
supply voltage.
If some one could point me to a web page with a circuit that I could use,
that would really help.
Bob
Original Message
> > From: Bob Phillips [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=eKGDlPFnPPIEXjXNwmdoRE6FtnZore6tHwUtvsyGggctOXipa0gGnEfM1-03Tz6Iz2Md5Y6l2A]robertp@v...[/url
> > Hello All,
> > Thanks
and
