Tone input — Parallax Forums
Tone input
edited 2003-03-07 13:19 in General Discussion
Hello All,
I cooked my first stamp and need some help as their expensive :-)
I want to use a tone around 2000 Hz picked by a microphone to turn a stamp
input to "0". If some one give me a little help I would be thankful. I'm
using a BOE with a BS2.
    edited 2003-03-03 18:02
    Amplify the tone with an op amp. Then use a diode rectifier to charge a
    capacitor (simple half wave rectifier). Use a 5.1 V zener diode to
    ensure that the input stays inside the 0.5-V and 5.1V positive limits
    which keeps TTL circuitry happy in life. I've done this before and it
    works well. Though admitadly not all in the same circuit at the same
    time.<G> I also have a BOE.
    From: Bob Phillips [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Etozwia8HBPkfvEWOWnIJweM25z68iQBP10FgA0xEI4ebf0Js4mYvtQ7h0WtUq__qTgfpBsN33LD]robertp@v...[/url
    Sent: Monday, March 03, 2003 11:03 AM
    Subject: Re: [noparse][[/noparse]basicstamps] Tone input
    Hello All,
    stamp input to "0". If some one give me a little help I would be
    thankful. I'm using a BOE with a BS2.
    Your use of Yahoo! Groups is subject to
    edited 2003-03-03 18:50
    Grover,
    Thanks for the input, (no pun).
    Why charge a capacitor ?? Other wise I'm with you.
    Bob Phillips
    > [noparse][[/noparse]Original Message]
    > From: Grover Richardson <grover.richardson@g...>
    > To: <basicstamps@yahoogroups.com>
    > Date: 3/3/2003 1:05:35 PM
    > Subject: RE: [noparse][[/noparse]basicstamps] Tone input
    > From: Bob Phillips [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=63diPbsVh-_vc67sbem8cbeNHBThSvkJNgKlxL-B81e1mWIhyeJeYM_f8DpcrjDXmy40nJdWAg]robertp@v...[/url
    > Hello All,
    > Thanks
    edited 2003-03-03 18:56
    I think the capacitor acts as a filter to further smooth out the
    current from the rectifier.
    Bill
    --- In basicstamps@yahoogroups.com, "Bob Phillips" <robertp@v...>
    wrote:
    > Grover,
    > Bob Phillips
    charge a
    to
    limits
    and it
    same
    > > From: Bob Phillips [noparse][[/noparse]mailto:robertp@v...]
    > > Hello All,
    turn a
    be
    > > Thanks
    Subject
    Subject and
    edited 2003-03-03 20:06
    At 11:02 AM 3/3/03 -0500, Bob Phillips wrote:
    >Hello All,
    Do a search for NE567 or XR567
    These are nice little 8 pin tone decoders that work very well. I've used
    thousands of them over the years.
    dwayne
    Dwayne Reid <dwayner@p...>
    Trinity Electronics Systems Ltd Edmonton, AB, CANADA
    (780) 489-3199 voice (780) 487-6397 fax
    Celebrating 19 years of Engineering Innovation (1984 - 2003)
    Do NOT send unsolicited commercial email to this email address.
    This message neither grants consent to receive unsolicited
    commercial email nor is intended to solicit commercial email.
    edited 2003-03-03 20:30
    Absolutely correct. This ensures a solid DC output from an ac signal.
    If the signal is just amplified, then squared, it is possible that the
    signal may be missed off and on due to the possibility that the signal
    may not be the desired level at the pin when the program is looking at
    the pin.
    One of the other fellas did mention a tone decoder. A more elegant
    method of doing things, but also very effective. There's more than one
    way to work out a solution many times<G>.
    From: billakay <billak@f...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=YXx1S1X0plZm1ZgquzQYyHpBTZZe2vfXWnQHZU6vVn0-zCtqu0SAf9PCeucvH2y89K8Dtso]billak@f...[/url
    Sent: Monday, March 03, 2003 1:57 PM
    Subject: [noparse][[/noparse]basicstamps] Re: Tone input
    Bill
    wrote:
    > Grover,
    > Bob Phillips
    charge a
    to
    limits
    and it
    same
    > > Hello All,
    turn a
    be
    > > Thanks
    Subject
    Subject and
    Hi All, do appreciate the help
    Whats the best op amp and configuration to use to amplifier the tone ?
    My input is .1 mVolts from the microphone. (2000 HZ)
    I have tried a 741 with little sucess, I would like to use a 12 volt dc
    supply voltage.
    If some one could point me to a web page with a circuit that I could use,
    that would really help.
    Bob
    > > From: Bob Phillips [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=eKGDlPFnPPIEXjXNwmdoRE6FtnZore6tHwUtvsyGggctOXipa0gGnEfM1-03Tz6Iz2Md5Y6l2A]robertp@v...[/url
    > > Hello All,
    > > Thanks
    and
