Do I *need* a socket for putting a stamp in a breadboard?
I just bought a basic stamp 2sx integrated chip (without any board
like the board of education). I tried hooking testing it out by
putting it on a breadboard along with appropriate serial lines and
power supply, but when I try to download anything to it via the DOS
basic stamp program it says 'hardware not detected' (I've tried
running it from DOS and windows). I believe the problem might be the
lack of a good stamp to breadboard connection. Do I need a socket to
put the stamp correctly in the breadboard? As is (without a socket),
the chip doesn't seem to go very far into the breaboard holes. Thank
you very much for your help.
-Sam
-Sam
hard-on@t... writes:
If you are plugging your serial cable into a DB9 female connector which is
connected to you breadboard, pins 5 and 6 on the breadboard DB9 need to be
shorted together.
Sid Weaver
W4EKQ
Port Richey, FL
cable to the breadboard by plugging the wires directly into the
breadboard.
--- In basicstamps@yahoogroups.com, Newzed@a... wrote:
> In a message dated 03/01/2003 19:57:25 Eastern Standard Time,
board
and
DOS
the
to
socket),
Thank
which is
need to be
> shorted together.
> Sid Weaver
> W4EKQ
> Port Richey, FL
> do you mean pins 6 and 7? I'm just connecting the wires from my db9
> breadboard.
I presume you are connecting your serial cable to a DB9 connector which is
connected to your breadboard. Pins 6 and 7 on the back of the breadboard DB9
must be shorted together.
Sid
> In a message dated 03/01/2003 20:10:52 Eastern Standard Time,
db9
> > breadboard.
which is
breadboard DB9
> Sid
I jusr shorted 6 and 7 together and still no go
stamp, I had one on a breadboard with stuff soldered
directly to the pins for a while. But then I
unsoldered everything and put it on a socket. Why?
Because sockets are cheap, so I can have several
projects revolving around one stamp. When I want to
work on a different project I just unplug the stamp
and have at it.
On a similar note, does anyone have a socket part
number for which the stamp fits completely into, i.e.,
the "belly of the stamp" sits on the socket? On the
ones I have found the stamp's pins are 1/8th inch (or
so) longer than the socket is deep . . .
__________________________________________________
Do you Yahoo!?
Yahoo! Tax Center - forms, calculators, tips, more
http://taxes.yahoo.com/
The Textool socket I mentionned earlier: 3M2402-ND (DigiKey).
The stamp's and any other IC's belly sits drectly on the socket.
I have a BOE and replaced the original socket with a Textool-ZIF
variant. Wile such a Textool costs about a thrid of a BS2 ($17),
you just lift the lever and there is no chance to even bend a pin.
An I change the stamp a lot.
Regards
Adrian
