Do I *need* a socket for putting a stamp in a breadboard? — Parallax Forums
edited 2003-03-03 15:34 in General Discussion
I just bought a basic stamp 2sx integrated chip (without any board
like the board of education). I tried hooking testing it out by
putting it on a breadboard along with appropriate serial lines and
power supply, but when I try to download anything to it via the DOS
basic stamp program it says 'hardware not detected' (I've tried
running it from DOS and windows). I believe the problem might be the
lack of a good stamp to breadboard connection. Do I need a socket to
put the stamp correctly in the breadboard? As is (without a socket),
the chip doesn't seem to go very far into the breaboard holes. Thank
you very much for your help.
-Sam
    edited 2003-03-02 01:00
    In a message dated 03/01/2003 19:57:25 Eastern Standard Time,
    hard-on@t... writes:
    If you are plugging your serial cable into a DB9 female connector which is
    connected to you breadboard, pins 5 and 6 on the breadboard DB9 need to be
    shorted together.
    Sid Weaver
    W4EKQ
    Port Richey, FL
    edited 2003-03-02 01:09
    do you mean pins 6 and 7? I'm just connecting the wires from my db9
    cable to the breadboard by plugging the wires directly into the
    breadboard.
    board
    and
    DOS
    the
    to
    socket),
    Thank
    which is
    need to be
    > shorted together.
    > Sid Weaver
    > W4EKQ
    > Port Richey, FL
    edited 2003-03-02 01:14
    In a message dated 03/01/2003 20:10:52 Eastern Standard Time,
    > breadboard.
    I presume you are connecting your serial cable to a DB9 connector which is
    connected to your breadboard. Pins 6 and 7 on the back of the breadboard DB9
    must be shorted together.
    Sid
    edited 2003-03-02 01:25
    db9
    > > breadboard.
    which is
    breadboard DB9
    > Sid
    I jusr shorted 6 and 7 together and still no go
    edited 2003-03-03 13:37
    You don't necessarily need a socket to wire up a
    stamp, I had one on a breadboard with stuff soldered
    directly to the pins for a while. But then I
    unsoldered everything and put it on a socket. Why?
    Because sockets are cheap, so I can have several
    projects revolving around one stamp. When I want to
    work on a different project I just unplug the stamp
    and have at it.
    On a similar note, does anyone have a socket part
    number for which the stamp fits completely into, i.e.,
    the "belly of the stamp" sits on the socket? On the
    ones I have found the stamp's pins are 1/8th inch (or
    so) longer than the socket is deep . . .
    __________________________________________________
    Do you Yahoo!?
    Yahoo! Tax Center - forms, calculators, tips, more
    http://taxes.yahoo.com/
    --- In basicstamps@yahoogroups.com, John Remington <jrem123@y...>
    The Textool socket I mentionned earlier: 3M2402-ND (DigiKey).
    The stamp's and any other IC's belly sits drectly on the socket.
    I have a BOE and replaced the original socket with a Textool-ZIF
    variant. Wile such a Textool costs about a thrid of a BS2 ($17),
    you just lift the lever and there is no chance to even bend a pin.
    An I change the stamp a lot.
    Regards
    Adrian
