Liquid turbine
Hi,
I would like to find some very small turbine to measure small amount of liquid
passing through
pipes . For example : diesel supplying an engine and return to the tank or water
going to a
water osmosis system and the outlet, etc... The material should support low
pressure and be
resistant to some chemical. The information will be worked out with a BASIC
STAMP. In most
case, like in the example above, I will need of a twin turbine or two separate
one to calculate
the exact amount used. Can someone help me to find that kind of device ?
Thanks.
Jean-Pol Deloyer
passing through
going to a
pressure and be
STAMP. In most
one to calculate
Thanks.
Jean-Pol Deloyer
You might try Omega
Engineering http://www.omega.com/toc_asp/sectionSC.asp?book=green§ion=f
At 09:06 PM 2/27/2003 +0100, you wrote:
>Hi,
>liquid passing through
>water going to a
>low pressure and be
>BASIC STAMP. In most
>separate one to calculate
>Thanks.
>Jean-Pol Deloyer
>To UNSUBSCRIBE, just send mail to:
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
_________________________________
Mike Walsh
walsh@i...
Jean-Pol
--- In basicstamps@yahoogroups.com, Mike Walsh <walsh@c...> wrote:
> Jean-Pol,
> You might try Omega
book=green§ion=f
> Mike
> >Hi,
amount of
tank or
> >water going to a
support
> >low pressure and be
with a
two
device ?
> >Thanks.
> >Jean-Pol Deloyer
Subject and
> Mike Walsh
> walsh@i...
water/sprinkler timer using shut-off solenoids and flow meters. I haven't
read it yet, but it might help.
Original Message
From: jpdeloyer <jpdeloyer@h...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=BNTUV0R53YGdy9tz-PiaCJjA4A39UCmG6V622bARYNwvHqSUkd9uaZyI2pz4tKfEEOO_MUUu0PJ9-Eg]jpdeloyer@h...[/url
Sent: Friday, February 28, 2003 9:50 AM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Re: Liquid turbine
Thanks a lot for your fast answer, but I am looking for cheeper items.
Jean-Pol
> Jean-Pol,
> You might try Omega
book=green§ion=f
> Mike
> >Hi,
amount of
tank or
> >water going to a
support
> >low pressure and be
with a
two
device ?
> >Thanks.
> >Jean-Pol Deloyer
Subject and
> Mike Walsh
> walsh@i...
Just a thought, but you may want to look into a small,
surplus liquid pump - vane type - that are run by DC
motors. When liguid is forced through the pump, it
will spin and the motor will generate a voltage
proportional to speed. The output voltage would need
to be calibrated against a known volume, unless your
looking for a relative reference. Just make sure that
the load doesn't affect what your measuring.
DrDiode
--- jpdeloyer@h... wrote:
> Hi,
> measure small amount of liquid passing through
> return to the tank or water going to a
> material should support low pressure and be
> worked out with a BASIC STAMP. In most
> twin turbine or two separate one to calculate
> Thanks.
> Jean-Pol Deloyer
> removed]
> Text in the Subject and Body of the message will be
> ignored.
__________________________________________________
Do you Yahoo!?
Yahoo! Tax Center - forms, calculators, tips, more
http://taxes.yahoo.com/
