Liquid turbine — Parallax Forums
Liquid turbine
edited 2003-03-05 01:33 in General Discussion
I would like to find some very small turbine to measure small amount of liquid
passing through
pipes . For example : diesel supplying an engine and return to the tank or water
going to a
water osmosis system and the outlet, etc... The material should support low
pressure and be
resistant to some chemical. The information will be worked out with a BASIC
STAMP. In most
case, like in the example above, I will need of a twin turbine or two separate
one to calculate
the exact amount used. Can someone help me to find that kind of device ?
Thanks.
Jean-Pol Deloyer
    edited 2003-02-27 20:28
    Jean-Pol,
    You might try Omega
    Engineering http://www.omega.com/toc_asp/sectionSC.asp?book=green&section=f
    At 09:06 PM 2/27/2003 +0100, you wrote:
    >Hi,
    >liquid passing through
    >water going to a
    >low pressure and be
    >BASIC STAMP. In most
    >separate one to calculate
    >Thanks.
    >Jean-Pol Deloyer
    >from the same email address that you subscribed. Text in the Subject and
    >Body of the message will be ignored.
    >Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    _________________________________
    Mike Walsh
    walsh@i...
    edited 2003-02-28 14:49
    Thanks a lot for your fast answer, but I am looking for cheeper items.
    Jean-Pol
    --- In basicstamps@yahoogroups.com, Mike Walsh <walsh@c...> wrote:
    > Jean-Pol,
    > You might try Omega
    > Mike
    > >Hi,
    amount of
    tank or
    > >water going to a
    support
    > >low pressure and be
    with a
    two
    device ?
    > >Thanks.
    > >Jean-Pol Deloyer
    Subject and
    > Mike Walsh
    > walsh@i...
    edited 2003-02-28 15:11
    Just got my Nuts and Volts magazine and it has an article about making a
    water/sprinkler timer using shut-off solenoids and flow meters. I haven't
    read it yet, but it might help.
    edited 2003-02-28 17:52
    Also check out the Nut&volt article this month. Just arrived today
    From: jpdeloyer <jpdeloyer@h...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=BNTUV0R53YGdy9tz-PiaCJjA4A39UCmG6V622bARYNwvHqSUkd9uaZyI2pz4tKfEEOO_MUUu0PJ9-Eg]jpdeloyer@h...[/url
    Sent: Friday, February 28, 2003 9:50 AM
    Subject: [noparse][[/noparse]basicstamps] Re: Liquid turbine
    Jean-Pol
    > Jean-Pol,
    > You might try Omega
    > Mike
    > >Hi,
    amount of
    tank or
    > >water going to a
    support
    > >low pressure and be
    with a
    two
    device ?
    > >Thanks.
    > >Jean-Pol Deloyer
    Subject and
    > Mike Walsh
    > walsh@i...
    Just a thought, but you may want to look into a small,
    surplus liquid pump - vane type - that are run by DC
    motors. When liguid is forced through the pump, it
    will spin and the motor will generate a voltage
    proportional to speed. The output voltage would need
    to be calibrated against a known volume, unless your
    looking for a relative reference. Just make sure that
    the load doesn't affect what your measuring.
    DrDiode
    --- jpdeloyer@h... wrote:
    > Hi,
    > measure small amount of liquid passing through
    > return to the tank or water going to a
    > material should support low pressure and be
    > worked out with a BASIC STAMP. In most
    > twin turbine or two separate one to calculate
    > Thanks.
    > Jean-Pol Deloyer
    > removed]
    > Text in the Subject and Body of the message will be
    > ignored.
    __________________________________________________
    Do you Yahoo!?
    Yahoo! Tax Center - forms, calculators, tips, more
    http://taxes.yahoo.com/
