Serial VFD Problems
I have a serial VFD display. It is supposed to operate @ 9600 n,8,1
baud. I'm trying to use it w/ my BS2 (it is TTL compatible), but I
can't get it to work. All I get is a bunch of garbage on the display.
There is info and a brief data sheet at:
http://www.dalewheat.com/projects/Serial%20VFD/
Please help if you can. Thank you.
-Brian Edmonson
-Brian Edmonson
-Brian Edmonson
I went through this with a crappy budget serial LCD and was getting the same
results. You need to know if it expects the serial line to be held low (at
ground) and swing up to 5 volts when data are sent (normal) or if it expects
the serial line to be held high (at 5 volts) and swing to ground when data
are sent (inverted). The Stamp will do either if you tell it to.You may also
need to have a pull-up or pull-down resistor on the serial line to keep the
line held in a constant state while the Stamp resets.
Look over the documentation and see if it mentions anything in particular.
Original Message
to see what results I'd get and it was the same garbage. I also
tried a pull up resistor w/o results but i didn't try a pull down
resistor. Thanks for your help.
-Brian
--- In basicstamps@yahoogroups.com, Rodent <daweasel@s...> wrote:
> Does the VFD expect a normal or inverted serial signal?
getting the same
low (at
it expects
when data
to.You may also
keep the
particular.
Original Message
n,8,1
I
display.
-Rob
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Tuesday, February 25, 2003 9:31 PM
Subject: [noparse][[/noparse]basicstamps] Re: Serial VFD Problems
> I'm pretty sure that it wants an inverted signal. But, i tried both
> -Brian
> getting the same
> low (at
> it expects
> when data
> to.You may also
> keep the
> particular.
Original Message
> n,8,1
> I
> display.
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
circuit) for RS232 to TTL inverts the signal, so the TTL input may be
normal. Try a 10k pull-down resistor and normal SEROUT mode and see what
happens. Also, just to be on the safe side, I would put a 220 ohm resistor
between the Stamp pin and the TTL input. Keep the Stamp pin low for a good
2-3 seconds before trying to send any serial data.
Original Message
> getting the same
> low (at
> it expects
> when data
> to.You may also
> keep the
> particular.
Original Message
> n,8,1
> I
> display.
wrote:
> Can you post the "serout" command you used.
> -Rob
Original Message
> From: <be068095552@y...>
both
> > -Brian
> > getting the same
held
> > low (at
if
> > it expects
ground
> > when data
> > to.You may also
line to
> > keep the
> > particular.
Original Message
9600
> > n,8,1
but
> > I
> > display.
Subject and
just fried the serial controller circuit. I accidentally reversed
the +V and GND and it is history. This bites! Thats my luck for ya.
Oh well, back to parallel inputs. :-( (good thing it wasn't brand
new).
-Brian Edmonson
I now double-triple-check my work before I apply power.
Original Message
> Thanks to everybody for your help, but I think we can quit now. I
> new).
