Serial VFD Problems
Archiver
I have a serial VFD display. It is supposed to operate @ 9600 n,8,1
baud. I'm trying to use it w/ my BS2 (it is TTL compatible), but I
can't get it to work. All I get is a bunch of garbage on the display.
There is info and a brief data sheet at:
http://www.dalewheat.com/projects/Serial%20VFD/
Please help if you can. Thank you.
-Brian Edmonson
-Brian Edmonson
-Brian Edmonson
I went through this with a crappy budget serial LCD and was getting the same
results. You need to know if it expects the serial line to be held low (at
ground) and swing up to 5 volts when data are sent (normal) or if it expects
the serial line to be held high (at 5 volts) and swing to ground when data
are sent (inverted). The Stamp will do either if you tell it to.You may also
need to have a pull-up or pull-down resistor on the serial line to keep the
line held in a constant state while the Stamp resets.
Look over the documentation and see if it mentions anything in particular.
to see what results I'd get and it was the same garbage. I also
tried a pull up resistor w/o results but i didn't try a pull down
resistor. Thanks for your help.
-Brian
--- In basicstamps@yahoogroups.com, Rodent <daweasel@s...> wrote:
> Does the VFD expect a normal or inverted serial signal?
getting the same
low (at
it expects
when data
to.You may also
keep the
particular.
n,8,1
I
display.
-Rob
Sent: Tuesday, February 25, 2003 9:31 PM
Subject: [noparse][[/noparse]basicstamps] Re: Serial VFD Problems
> I'm pretty sure that it wants an inverted signal. But, i tried both
> -Brian
> getting the same
> low (at
> it expects
> when data
> to.You may also
> keep the
> particular.
> n,8,1
> I
> display.
circuit) for RS232 to TTL inverts the signal, so the TTL input may be
normal. Try a 10k pull-down resistor and normal SEROUT mode and see what
happens. Also, just to be on the safe side, I would put a 220 ohm resistor
between the Stamp pin and the TTL input. Keep the Stamp pin low for a good
2-3 seconds before trying to send any serial data.
> getting the same
> low (at
> it expects
> when data
> to.You may also
> keep the
> particular.
> n,8,1
> I
> display.
wrote:
> Can you post the "serout" command you used.
> -Rob
> From: <be068095552@y...>
both
> > -Brian
> > getting the same
held
> > low (at
if
> > it expects
ground
> > when data
> > to.You may also
line to
> > keep the
> > particular.
9600
> > n,8,1
but
> > I
> > display.
Subject and
just fried the serial controller circuit. I accidentally reversed
the +V and GND and it is history. This bites! Thats my luck for ya.
Oh well, back to parallel inputs. :-( (good thing it wasn't brand
new).
-Brian Edmonson
I now double-triple-check my work before I apply power.
> Thanks to everybody for your help, but I think we can quit now. I
> new).
