Interfacing with a HCTL-1100
Hello All!
I am working on a Senior Thesis project. We are tackling a SLAM
problem, and currently I am trying to use a Basic Stamp 2 to
interface to two HCTL-1100 precision motion controllers. I was
curious if anyone had ever attempted this type of project before. A
quick web search did not produce anything of substance. Would be
interested if anyone has any helpful suggestions.
-Jim
-Jim
controller? If not, start there. The BS2 can use synchronous and
asynchronous serial, as well as I2C (with code) -- chances are you can
control it with the BASIC Stamp if it uses a standardized interface.
I'll bet that a quick web search (I like Google, but there are other good
search engines) will net a lot of useful information.
-- Jon Williams
-- Applications Engineer, Parallax
In a message dated 2/12/2003 10:59:43 AM Central Standard Time,
lelechuck@e... writes:
> Hello All!
> -Jim
multiplexed address/data bus. The data sheet has plenty on
information on addressing. I was hoping someone out there might have
already done some development for a similar system.
-Jim
--- In basicstamps@yahoogroups.com, jonwms@a... wrote:
> At the risk of asking the obvious ... do you have the specs on the
motor
can
other good
> -- Jon Williams
> > Hello All!
before. A
> > -Jim
