Interfacing with a HCTL-1100 — Parallax Forums
edited 2003-02-12 18:48 in General Discussion
Hello All!
I am working on a Senior Thesis project. We are tackling a SLAM
problem, and currently I am trying to use a Basic Stamp 2 to
interface to two HCTL-1100 precision motion controllers. I was
curious if anyone had ever attempted this type of project before. A
quick web search did not produce anything of substance. Would be
interested if anyone has any helpful suggestions.
-Jim
    edited 2003-02-12 17:58
    At the risk of asking the obvious ... do you have the specs on the motor
    controller? If not, start there. The BS2 can use synchronous and
    asynchronous serial, as well as I2C (with code) -- chances are you can
    control it with the BASIC Stamp if it uses a standardized interface.
    I'll bet that a quick web search (I like Google, but there are other good
    search engines) will net a lot of useful information.
    -- Jon Williams
    In a message dated 2/12/2003 10:59:43 AM Central Standard Time,
    lelechuck@e... writes:
    > Hello All!
    > -Jim
    It's ok... I did, and the HCTL-1100 uses an An 8-bit bi-directional
    multiplexed address/data bus. The data sheet has plenty on
    information on addressing. I was hoping someone out there might have
    already done some development for a similar system.
    -Jim
    motor
    can
    other good
    > -- Jon Williams
    > > Hello All!
    before. A
    > > -Jim
