12v Motor control with photo-resistor. Help
I am just starting to work with Basic stamps and want a photo-resistor to
control a 12v motor (Easy Roller). What do I need? An H-bridge? Just a
carrier board?
I have gotten a servo to work with the photo-resistor, but the 12v motor is
stumping me.
Any help would be great.
Kevin
carrier board?
stumping me.
Kevin
The servo thing works because the Stamp pin does not actually power the
servo itself -- it only provides a control signal that tells the servo where
to move to. A circuit inside the servo actually controls the servo motor.
With a 12-volt motor, the Stamp pin is not capable of providing enough power
to run the motor. You have to use some sort of external circuit to control
the motor power. If you want to be able to make the motor go different
speeds and change directions you do need an H-bridge. If you need a single
speed and direction, its much easier.
I didn't see anything in the StampWorks section on DC motors, so you may
want to browse the Nuts & Volts articles on Parallax' web site and see what
they have:
http://www.parallax.com/html_pages/resources/nvcolumns/Nuts_Volts_Downloads.
asp
Original Message
> carrier board?
is
> stumping me.
Just looked at the Nuts & Volts articles, but didn't see anything.
Kevin
-- In basicstamps@yahoogroups.com, Rodent <daweasel@s...> wrote:
> Kevin,
power
single
> they have:
> asp
Original Message
> > carrier board?
> is
> > stumping me.
site right away. I'll see if I can locate it later.
Original Message
where
motor.
> power
control
> single
