12v Motor control with photo-resistor. Help — Parallax Forums
edited 2003-02-11 04:32 in General Discussion
I am just starting to work with Basic stamps and want a photo-resistor to
control a 12v motor (Easy Roller). What do I need? An H-bridge? Just a
carrier board?
I have gotten a servo to work with the photo-resistor, but the 12v motor is
stumping me.
Any help would be great.
Kevin
    edited 2003-02-11 02:18
    Kevin,
    The servo thing works because the Stamp pin does not actually power the
    servo itself -- it only provides a control signal that tells the servo where
    to move to. A circuit inside the servo actually controls the servo motor.
    With a 12-volt motor, the Stamp pin is not capable of providing enough power
    to run the motor. You have to use some sort of external circuit to control
    the motor power. If you want to be able to make the motor go different
    speeds and change directions you do need an H-bridge. If you need a single
    speed and direction, its much easier.
    I didn't see anything in the StampWorks section on DC motors, so you may
    want to browse the Nuts & Volts articles on Parallax' web site and see what
    they have:
    http://www.parallax.com/html_pages/resources/nvcolumns/Nuts_Volts_Downloads.
    asp
    > carrier board?
    is
    > stumping me.
    edited 2003-02-11 02:54
    Ok Now I understand Thanks !!!
    Just looked at the Nuts & Volts articles, but didn't see anything.
    Kevin
    -- In basicstamps@yahoogroups.com, Rodent <daweasel@s...> wrote:
    > Kevin,
    power
    single
    > they have:
    > asp
    > > carrier board?
    > is
    > > stumping me.
    I think it may be in the Stamps in Class stuff, but I didn't see it on the
    site right away. I'll see if I can locate it later.
    where
    motor.
    > power
    control
    > single
