memsic 2125 accelerometer from parallax
First I just want to thank parallax for their memsic accelerometer unit.
I'm very impressed with it so far.
Now on to the question.
Using the code straight from parallax it seems the longer the wires are to
the accelerometer the less G's are registered at 90 degrees off level on
either axis. The three feet of wire I have leading to the accelerometer
unit cause it to register .960. When I reduce this to 6 inches it reads
1.000. Is this due to the wire itself, the length of it, or do I need some
kind of buffer/driver closer to the accelerometer for a 3 foot cable run?
BTW I'm using 1 pair from a length of CAT5 for power and a second pair for
X/Y signals. Maybe I should try a separate pair for X and Y with one lead
tied to ground and the signal on the other?
-Rob
-Rob
for data, one for data ground, and tie the shield to ground on one end only.
Does it work OK if you only hook up / monitor one axis?
Got me a couple of them things sitting on the bench also -- waiting to
figure out what to build. Are they sensitive enough to make an electronic
level?
Original Message
some
about it (it will be installed in my auto-cross track car).
They are fairly sensative. The parallax demo code produces a result that is
"chunky", so level is .000 it moves to .008, then .016. The demo code also
shows the degrees of tilt, but I can't quite remember the resolution because
I commented out that section of code shortly after hooking it up for a test.
I just had to see how fast I could get it to update on a LCD so I commented
out everything I could. I do think it could be used as an electronic level,
but it wouldn't be much more accurate than eyeing up the bubble on a normal
level.
I was thinking about putting all my spare parts together and maybe fit
together a robot and use the memsic unit to keep the robot from tipping
itself while attempting an incline. Even make a device that logged
time/date of peaks in G's, then use that to keep an eye on movers, UPS, etc
[noparse];)[/noparse] So many ideas for such a small thing.
Rob
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Monday, February 10, 2003 12:27 AM
Subject: Re: [noparse][[/noparse]basicstamps] memsic 2125 accelerometer from parallax
> Might try running two separate two-conductor shielded cables. One
conductor
only.
> level?
Original Message
to
> some
run?
for
lead
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
shielded cable solution worked. I may be running into this problem myself in
the future.
James
Original Message
Sent: 02/10/03 07:59 AM
To: basicstamps@yahoogroups.com
> I'll try shielded cables, I should be using that anyway the more I think
is
also
because
test.
commented
level,
normal
level.
etc
Rob
Original Message
conductor
only.
electronic
> level?
Original Message
unit.
are
to
on
accelerometer
reads
> some
run?
for
lead
and
for a wide range of users. That said, the specs are available from Memsic
and through different methods you can get finer resolution in the results.
My December Nuts & Volts article uses a different method for angular
calculation and returns much finer movements than the demo code that ships
with the product.
There's always more than one way to skin a cat....
BTW, we have put the Memsic to use in our Toddler robot with quite a bit of
success. I will be putting it into our SumoBot as well.
-- Jon Williams
-- Parallax
In a message dated 2/10/2003 8:10:22 AM Central Standard Time,
rstaph@a... writes:
> is
> because
> test.
> level,
> level.
> Rob
easier to see what's going on, which I'm sure was the intended effect.
Someone of a higher skill level like yourself, Jon, would most likely be
able to extract a higher degree of accuracy.
The memsic unit is well worth what parallax is charging, especially because
it seems to have an over all survivability edge on certain other
accelerometers.
Rob
Original Message
Sent: Monday, February 10, 2003 11:23 AM
> The Parallax code is "chunky" because we have to keep examples fairly
simple
> with the product.
of
> -- Jon Williams
> -- Parallax
> rstaph@a... writes:
that
> > is
also
> > because
> > test.
commented
> > level,
normal
> > level.
etc
> > Rob
We try to sell things at a fair price; enough to pay our employees, provide
support materials for our customers, and develop new products.
The Memsic 2125 is a neat device and due to its unique design has a much
better shock tolerance than similar products.
-- Jon Williams
-- Parallax
In a message dated 2/10/2003 12:44:20 PM Central Standard Time,
rstaph@a... writes:
> accelerometers.
