memsic 2125 accelerometer from parallax — Parallax Forums
edited 2003-02-10 19:02 in General Discussion
First I just want to thank parallax for their memsic accelerometer unit.
I'm very impressed with it so far.
Now on to the question.
Using the code straight from parallax it seems the longer the wires are to
the accelerometer the less G's are registered at 90 degrees off level on
either axis. The three feet of wire I have leading to the accelerometer
unit cause it to register .960. When I reduce this to 6 inches it reads
1.000. Is this due to the wire itself, the length of it, or do I need some
kind of buffer/driver closer to the accelerometer for a 3 foot cable run?
BTW I'm using 1 pair from a length of CAT5 for power and a second pair for
X/Y signals. Maybe I should try a separate pair for X and Y with one lead
tied to ground and the signal on the other?
-Rob
    edited 2003-02-10 05:27
    Might try running two separate two-conductor shielded cables. One conductor
    for data, one for data ground, and tie the shield to ground on one end only.
    Does it work OK if you only hook up / monitor one axis?
    Got me a couple of them things sitting on the bench also -- waiting to
    figure out what to build. Are they sensitive enough to make an electronic
    level?
    some
    edited 2003-02-10 13:59
    I'll try shielded cables, I should be using that anyway the more I think
    about it (it will be installed in my auto-cross track car).
    They are fairly sensative. The parallax demo code produces a result that is
    "chunky", so level is .000 it moves to .008, then .016. The demo code also
    shows the degrees of tilt, but I can't quite remember the resolution because
    I commented out that section of code shortly after hooking it up for a test.
    I just had to see how fast I could get it to update on a LCD so I commented
    out everything I could. I do think it could be used as an electronic level,
    but it wouldn't be much more accurate than eyeing up the bubble on a normal
    level.
    I was thinking about putting all my spare parts together and maybe fit
    together a robot and use the memsic unit to keep the robot from tipping
    itself while attempting an incline. Even make a device that logged
    time/date of peaks in G's, then use that to keep an eye on movers, UPS, etc
    [noparse];)[/noparse] So many ideas for such a small thing.
    Rob
    Sent: Monday, February 10, 2003 12:27 AM
    Subject: Re: [noparse][[/noparse]basicstamps] memsic 2125 accelerometer from parallax
    conductor
    only.
    > level?
    to
    > some
    run?
    for
    lead
    edited 2003-02-10 14:16
    I would appreciate it if you could mention after the fact how effective the
    shielded cable solution worked. I may be running into this problem myself in
    the future.
    James
    Sent: 02/10/03 07:59 AM
    is
    also
    because
    test.
    commented
    level,
    normal
    level.
    etc
    Rob
    conductor
    only.
    electronic
    > level?
    unit.
    are
    to
    on
    accelerometer
    reads
    > some
    run?
    for
    lead
    and
    edited 2003-02-10 16:23
    The Parallax code is "chunky" because we have to keep examples fairly simple
    for a wide range of users. That said, the specs are available from Memsic
    and through different methods you can get finer resolution in the results.
    My December Nuts & Volts article uses a different method for angular
    calculation and returns much finer movements than the demo code that ships
    with the product.
    There's always more than one way to skin a cat....
    BTW, we have put the Memsic to use in our Toddler robot with quite a bit of
    success. I will be putting it into our SumoBot as well.
    -- Jon Williams
    -- Parallax
    In a message dated 2/10/2003 8:10:22 AM Central Standard Time,
    rstaph@a... writes:
    > is
    > because
    > test.
    > level,
    > level.
    > Rob
    edited 2003-02-10 18:33
    I didn't mean for the "chunky" comment to be negative. It made it much
    easier to see what's going on, which I'm sure was the intended effect.
    Someone of a higher skill level like yourself, Jon, would most likely be
    able to extract a higher degree of accuracy.
    The memsic unit is well worth what parallax is charging, especially because
    it seems to have an over all survivability edge on certain other
    accelerometers.
    Rob
    Sent: Monday, February 10, 2003 11:23 AM
    simple
    > with the product.
    of
    > -- Jon Williams
    > -- Parallax
    > rstaph@a... writes:
    that
    > > is
    also
    > > because
    > > test.
    commented
    > > level,
    normal
    > > level.
    etc
    > > Rob
    Despite urban legends to the contrary, we're not getting rich at Parallax.
    We try to sell things at a fair price; enough to pay our employees, provide
    support materials for our customers, and develop new products.
    The Memsic 2125 is a neat device and due to its unique design has a much
    better shock tolerance than similar products.
    -- Jon Williams
    -- Parallax
    In a message dated 2/10/2003 12:44:20 PM Central Standard Time,
    rstaph@a... writes:
    > accelerometers.
