Clock code advice
Hi All,
Well, now that I have figured out how to drive my Nixies, it is time to
figure out the code ;-)
I am looking for advice on the best way to structure my code. I will be
receiving my time information in decimal format from WWBV receiver, i.e.:
hrs=12 min =30 seconds= 30. So I will chop that up into hrs_High, hrs_Low,
etc. I then need to compare the time and send the correct pins high/low so
the decoder lights the correct digit. What is the best way to organize this?
I could do a bunch of if/thens like:
if hrs_high = 1 then hrs_high_one
if hrs_high = 2 then hrs_high_two
and so one. But this is the dumb guy way (which is why it occurred to me)
but I know there is a better way. I just can't see it ;-) I need to keep the
code pretty streamlined, as the clock has seconds I have less than a second
to perform everything.
Thanks all!
Jonathan
www.madlabs.info
Thanks all!
Jonathan
www.madlabs.info
ZEROPATTERN con xxxx ' pattern to make a zero
ONEPATTERN con xxxx ' pattern to make a one
Etc.
LOOKUP hrs_high,[noparse][[/noparse]ZEROPATTERN, ONEPATTERN, TWOPATTERN,...],outdigit
Digit=5
Gosub selectdigit ' pick the digit
Gosub writedigit ' write outdigit
<repeat>
Al Williams
AWC
* Control 8 servos at once
http://www.al-williams.com/awce/pak8.htm
Original Message
> From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ICUCbwmJLJ9Kcn9DuVT2OEUtJ0UXRlDAxsgbkruyyAr-4DtbHmKP1EZeb9dxODxOz-2cYqgbVuvchRljOW5T]jpeakall@m...[/url
> Sent: Saturday, February 01, 2003 10:05 AM
> To: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] Clock code advice
> Hi All,
> is time to figure out the code ;-)
> I will be receiving my time information in decimal format
> from WWBV receiver, i.e.: hrs=12 min =30 seconds= 30. So I
> will chop that up into hrs_High, hrs_Low, etc. I then need to
> compare the time and send the correct pins high/low so the
> organize this? I could do a bunch of if/thens like:
> occurred to me) but I know there is a better way. I just
> can't see it ;-) I need to keep the code pretty streamlined,
> as the clock has seconds I have less than a second to perform
> everything.
> Thanks all!
> Jonathan
> www.madlabs.info
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the
> Subject and Body of the message will be ignored.
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
with the new editor [noparse][[/noparse]you need to download the Beta 1 from our web site]. So
you could also do something like this:
Show_Hours_Tens:
SELECT (hours / 10)
CASE 0
' code to display 0
CASE 1
' code to display 1
CASE 2
' code to display 2
ENDSELECT
RETURN
To handle the low digit of hours, you would simply change the expression to
"hours // 10." I don't know how your Nixie drivers work, but there's
certainly the chance that you could create single SELECT CASE construct that
accepts a digit position, a value, then takes care of displaying it.
-- Jon Williams
-- Parallax
In a message dated 2/1/2003 10:05:24 AM Central Standard Time, jpeakall@mad
labs.info writes:
> this?
> the
interesting project..
Leroy
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Saturday, February 01, 2003 11:05 AM
: Hi All,
: Well, now that I have figured out how to drive my Nixies, it is time to
: figure out the code ;-)
: I am looking for advice on the best way to structure my code. I will be
: receiving my time information in decimal format from WWBV receiver, i.e.:
: hrs=12 min =30 seconds= 30. So I will chop that up into hrs_High, hrs_Low,
: etc. I then need to compare the time and send the correct pins high/low so
: the decoder lights the correct digit. What is the best way to organize this?
: I could do a bunch of if/thens like:
: if hrs_high = 1 then hrs_high_one
: if hrs_high = 2 then hrs_high_two
: and so one. But this is the dumb guy way (which is why it occurred to me)
: but I know there is a better way. I just can't see it ;-) I need to keep the
: code pretty streamlined, as the clock has seconds I have less than a second
: to perform everything.
: Thanks all!
: Jonathan
: www.madlabs.info
: To UNSUBSCRIBE, just send mail to:
: basicstamps-unsubscribe@yahoogroups.com
: from the same email address that you subscribed. Text in the Subject and Body
of the
: Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
>etc.
Hi Jonathan,
You have to be careful with the notation.
If it is in fact BCD (binary coded decimal), then what you will
receive is hrs=$12, min=$30 and seconds=$30. (denoted as HEX) And
in that case what you said about hrs_High etc is correct, to extract
the digits. That is what Al followed up on.
But it the values are really hrs=12, min=30 and seconds=30 as stated,
then that is different, and the method that Jon suggested using
hrs/10 and hrs//10 will extract the digits, or you could
alternatively use hrs dig 1 and hrs dig 0.
Just to add one more method to the mix, here is a way to read the
patterns from eeprom. (Like the one Al suggested using LOOKUP).
'{$PBASIC 2.5}
patterns data pzero,pone,ptwo ',... all ten digit patterns stored in eeprom
pattern var byte
do
gosub getclockreading
' assume BCD, e.g. hrs.nib1=1, hrs.nib0=2 for 12 oclock
read patterns+hours.nib1,pattern ' get the pattern from eeprom
digit=hours10 ' showdigit takes pattern and digit as input
gosub showdigit ' 10s of hours
read patterns+hours.nib0,pattern ' get the pattern
digit=hours1
gosub showdigit ' 1s of hours
' and so on for all the digits
' it might be possible to reduce this to one for-next loop
' if the digits are well placed consecutively in RAM.
loop
-- Tracy
Thanks for the ideas! I'm sure more questions will develop as I go along ;-)
Leroy, I am using a WWBV reciver that Parallax used to sell, but is now
discontinued. The company that made it only has expensive units now. I was
using a $15 wwbv clock that I hacked, and if I can figure out extracting the
date from it, I may use it for this project too.
Jonathan
www.madlabs.info
Original Message
Sent: Saturday, February 01, 2003 10:55 AM
Subject: Re: [noparse][[/noparse]basicstamps] Clock code advice
> > I will be
hrs_Low,
> >etc.
> Hi Jonathan,
> '{$PBASIC 2.5}
eeprom
> pattern var byte
> do
> digit=hours1
> loop
> -- Tracy
You might be interested in:
http://www.amug.org/~jthomas/example.pdf
http://www.amug.org/~jthomas/wwvb.html
for your clock..
I looked at your website and was interested in the 'sound laser' and the sound
refrigerator. Is there any information about these subjects a little easier to
understand? I read them, but am looking for more info.
Leroy
Original Message
Sent: Sunday, February 02, 2003 9:20 AM
: Tracy, Jon, Al, Leroy,
: Thanks for the ideas! I'm sure more questions will develop as I go along ;-)
: Leroy, I am using a WWBV reciver that Parallax used to sell, but is now
: discontinued. The company that made it only has expensive units now. I was
: using a $15 wwbv clock that I hacked, and if I can figure out extracting the
: date from it, I may use it for this project too.
: Jonathan
: www.madlabs.info
Original Message
: From: "Tracy Allen" <tracy@e...>
: To: <basicstamps@yahoogroups.com>
: Sent: Saturday, February 01, 2003 10:55 AM
: Subject: Re: [noparse][[/noparse]basicstamps] Clock code advice
: > > I will be
: > >receiving my time information in decimal format from WWBV receiver, i.e.:
: > >hrs=12 min =30 seconds= 30. So I will chop that up into hrs_High,
: hrs_Low,
: > >etc.
: > Hi Jonathan,
: > You have to be careful with the notation.
: > If it is in fact BCD (binary coded decimal), then what you will
: > receive is hrs=$12, min=$30 and seconds=$30. (denoted as HEX) And
: > in that case what you said about hrs_High etc is correct, to extract
: > the digits. That is what Al followed up on.
: > But it the values are really hrs=12, min=30 and seconds=30 as stated,
: > then that is different, and the method that Jon suggested using
: > hrs/10 and hrs//10 will extract the digits, or you could
: > alternatively use hrs dig 1 and hrs dig 0.
: > Just to add one more method to the mix, here is a way to read the
: > patterns from eeprom. (Like the one Al suggested using LOOKUP).
: > '{$PBASIC 2.5}
: > patterns data pzero,pone,ptwo ',... all ten digit patterns stored in
: eeprom
: > pattern var byte
: > do
: > gosub getclockreading
: > ' assume BCD, e.g. hrs.nib1=1, hrs.nib0=2 for 12 oclock
: > read patterns+hours.nib1,pattern ' get the pattern from eeprom
: > digit=hours10 ' showdigit takes pattern and digit as input
: > gosub showdigit ' 10s of hours
: > read patterns+hours.nib0,pattern ' get the pattern
: > digit=hours1
: > gosub showdigit ' 1s of hours
: > ' and so on for all the digits
: > ' it might be possible to reduce this to one for-next loop
: > ' if the digits are well placed consecutively in RAM.
: > loop
: > -- Tracy
: > To UNSUBSCRIBE, just send mail to:
: > basicstamps-unsubscribe@yahoogroups.com
: > from the same email address that you subscribed. Text in the Subject and
: Body of the message will be ignored.
: > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
of the
I saw that site. It was funny, as I had a partially dissassembled clock of
the same type on my desk when I found it. I do plan to look at it some more
to figure out extracting the date.
Not much information about the acuostic laser, pretty new stuff. I made the
ones you saw from that article you read, and that was all I found. I still
have a couple pieces of substrate, if you want one.
Jonathan
www.madlabs.info
Original Message
Sent: Sunday, February 02, 2003 10:18 AM
> Dear Jonathan,
> or
> for your clock..
sound
easier to
> Leroy
Original Message
> From: "Jonathan Peakall" <jpeakall@m...>
was
the
> : Jonathan
> : www.madlabs.info
Original Message
> : > > I will be
i.e.:
> : hrs_Low,
> : > >etc.
> : > Hi Jonathan,
> : > '{$PBASIC 2.5}
> : eeprom
> : > do
> : > digit=hours1
> : > loop
> : > -- Tracy
and
and Body of the
