Clock code advice — Parallax Forums
Clock code advice
edited 2003-02-02 20:16 in General Discussion
Hi All,
Well, now that I have figured out how to drive my Nixies, it is time to
figure out the code ;-)
I am looking for advice on the best way to structure my code. I will be
receiving my time information in decimal format from WWBV receiver, i.e.:
hrs=12 min =30 seconds= 30. So I will chop that up into hrs_High, hrs_Low,
etc. I then need to compare the time and send the correct pins high/low so
the decoder lights the correct digit. What is the best way to organize this?
I could do a bunch of if/thens like:
if hrs_high = 1 then hrs_high_one
if hrs_high = 2 then hrs_high_two
and so one. But this is the dumb guy way (which is why it occurred to me)
but I know there is a better way. I just can't see it ;-) I need to keep the
code pretty streamlined, as the clock has seconds I have less than a second
to perform everything.
Thanks all!
Jonathan
www.madlabs.info
    edited 2003-02-01 16:10
    Can you load the pattern using lookup?
    ZEROPATTERN con xxxx ' pattern to make a zero
    ONEPATTERN con xxxx ' pattern to make a one
    Etc.
    LOOKUP hrs_high,[noparse][[/noparse]ZEROPATTERN, ONEPATTERN, TWOPATTERN,...],outdigit
    Digit=5
    Gosub selectdigit ' pick the digit
    Gosub writedigit ' write outdigit
    <repeat>
    Al Williams
    AWC
    * Control 8 servos at once
    http://www.al-williams.com/awce/pak8.htm
    > From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ICUCbwmJLJ9Kcn9DuVT2OEUtJ0UXRlDAxsgbkruyyAr-4DtbHmKP1EZeb9dxODxOz-2cYqgbVuvchRljOW5T]jpeakall@m...[/url
    > Sent: Saturday, February 01, 2003 10:05 AM
    > Subject: [noparse][[/noparse]basicstamps] Clock code advice
    > Hi All,
    > is time to figure out the code ;-)
    > I will be receiving my time information in decimal format
    > from WWBV receiver, i.e.: hrs=12 min =30 seconds= 30. So I
    > will chop that up into hrs_High, hrs_Low, etc. I then need to
    > compare the time and send the correct pins high/low so the
    > organize this? I could do a bunch of if/thens like:
    > occurred to me) but I know there is a better way. I just
    > can't see it ;-) I need to keep the code pretty streamlined,
    > as the clock has seconds I have less than a second to perform
    > everything.
    > Thanks all!
    > Jonathan
    > www.madlabs.info
    > from the same email address that you subscribed. Text in the
    edited 2003-02-01 16:27
    As my friend, Al, pointed out you can use LOOKUP, or you can use SELECT CASE
    with the new editor [noparse][[/noparse]you need to download the Beta 1 from our web site]. So
    you could also do something like this:
    Show_Hours_Tens:
    SELECT (hours / 10)
    CASE 0
    ' code to display 0
    CASE 1
    ' code to display 1
    CASE 2
    ' code to display 2
    ENDSELECT
    RETURN
    To handle the low digit of hours, you would simply change the expression to
    "hours // 10." I don't know how your Nixie drivers work, but there's
    certainly the chance that you could create single SELECT CASE construct that
    accepts a digit position, a value, then takes care of displaying it.
    -- Jon Williams
    -- Parallax
    In a message dated 2/1/2003 10:05:24 AM Central Standard Time, jpeakall@mad
    labs.info writes:
    > this?
    > the
    edited 2003-02-01 18:45
    What kind of radio are you using to pick up the WWBV signal? Sounds like a very
    interesting project..
    Leroy
    Sent: Saturday, February 01, 2003 11:05 AM
    : Hi All,
    : Well, now that I have figured out how to drive my Nixies, it is time to
    : figure out the code ;-)
    : I am looking for advice on the best way to structure my code. I will be
    : receiving my time information in decimal format from WWBV receiver, i.e.:
    : hrs=12 min =30 seconds= 30. So I will chop that up into hrs_High, hrs_Low,
    : etc. I then need to compare the time and send the correct pins high/low so
    : the decoder lights the correct digit. What is the best way to organize this?
    : I could do a bunch of if/thens like:
    : if hrs_high = 1 then hrs_high_one
    : if hrs_high = 2 then hrs_high_two
    : and so one. But this is the dumb guy way (which is why it occurred to me)
    : but I know there is a better way. I just can't see it ;-) I need to keep the
    : code pretty streamlined, as the clock has seconds I have less than a second
    : to perform everything.
    : Thanks all!
    : Jonathan
    : www.madlabs.info
    : To UNSUBSCRIBE, just send mail to:
    : basicstamps-unsubscribe@yahoogroups.com
    : from the same email address that you subscribed. Text in the Subject and Body
    of the
    : Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    edited 2003-02-01 18:55
    > I will be
    >etc.
    Hi Jonathan,
    You have to be careful with the notation.
    If it is in fact BCD (binary coded decimal), then what you will
    receive is hrs=$12, min=$30 and seconds=$30. (denoted as HEX) And
    in that case what you said about hrs_High etc is correct, to extract
    the digits. That is what Al followed up on.
    But it the values are really hrs=12, min=30 and seconds=30 as stated,
    then that is different, and the method that Jon suggested using
    hrs/10 and hrs//10 will extract the digits, or you could
    alternatively use hrs dig 1 and hrs dig 0.
    Just to add one more method to the mix, here is a way to read the
    patterns from eeprom. (Like the one Al suggested using LOOKUP).
    '{$PBASIC 2.5}
    patterns data pzero,pone,ptwo ',... all ten digit patterns stored in eeprom
    pattern var byte
    do
    gosub getclockreading
    ' assume BCD, e.g. hrs.nib1=1, hrs.nib0=2 for 12 oclock
    read patterns+hours.nib1,pattern ' get the pattern from eeprom
    digit=hours10 ' showdigit takes pattern and digit as input
    gosub showdigit ' 10s of hours
    read patterns+hours.nib0,pattern ' get the pattern
    digit=hours1
    gosub showdigit ' 1s of hours
    ' and so on for all the digits
    ' it might be possible to reduce this to one for-next loop
    ' if the digits are well placed consecutively in RAM.
    loop
    -- Tracy
    edited 2003-02-02 14:20
    Tracy, Jon, Al, Leroy,
    Thanks for the ideas! I'm sure more questions will develop as I go along ;-)
    Leroy, I am using a WWBV reciver that Parallax used to sell, but is now
    discontinued. The company that made it only has expensive units now. I was
    using a $15 wwbv clock that I hacked, and if I can figure out extracting the
    date from it, I may use it for this project too.
    Jonathan
    www.madlabs.info
    Sent: Saturday, February 01, 2003 10:55 AM
    Subject: Re: [noparse][[/noparse]basicstamps] Clock code advice
    > > I will be
    hrs_Low,
    > >etc.
    > Hi Jonathan,
    > '{$PBASIC 2.5}
    eeprom
    > pattern var byte
    > do
    > digit=hours1
    > loop
    > -- Tracy
    edited 2003-02-02 18:18
    Dear Jonathan,
    You might be interested in:
    http://www.amug.org/~jthomas/example.pdf
    http://www.amug.org/~jthomas/wwvb.html
    for your clock..
    I looked at your website and was interested in the 'sound laser' and the sound
    refrigerator. Is there any information about these subjects a little easier to
    understand? I read them, but am looking for more info.
    Leroy
    Sent: Sunday, February 02, 2003 9:20 AM
    : Tracy, Jon, Al, Leroy,
    : Thanks for the ideas! I'm sure more questions will develop as I go along ;-)
    : Leroy, I am using a WWBV reciver that Parallax used to sell, but is now
    : discontinued. The company that made it only has expensive units now. I was
    : using a $15 wwbv clock that I hacked, and if I can figure out extracting the
    : date from it, I may use it for this project too.
    : Jonathan
    : www.madlabs.info
    : From: "Tracy Allen" <tracy@e...>
    : To: <basicstamps@yahoogroups.com>
    : Sent: Saturday, February 01, 2003 10:55 AM
    : Subject: Re: [noparse][[/noparse]basicstamps] Clock code advice
    : > > I will be
    : > >receiving my time information in decimal format from WWBV receiver, i.e.:
    : > >hrs=12 min =30 seconds= 30. So I will chop that up into hrs_High,
    : hrs_Low,
    : > >etc.
    : > Hi Jonathan,
    : > You have to be careful with the notation.
    : > If it is in fact BCD (binary coded decimal), then what you will
    : > receive is hrs=$12, min=$30 and seconds=$30. (denoted as HEX) And
    : > in that case what you said about hrs_High etc is correct, to extract
    : > the digits. That is what Al followed up on.
    : > But it the values are really hrs=12, min=30 and seconds=30 as stated,
    : > then that is different, and the method that Jon suggested using
    : > hrs/10 and hrs//10 will extract the digits, or you could
    : > alternatively use hrs dig 1 and hrs dig 0.
    : > Just to add one more method to the mix, here is a way to read the
    : > patterns from eeprom. (Like the one Al suggested using LOOKUP).
    : > '{$PBASIC 2.5}
    : > patterns data pzero,pone,ptwo ',... all ten digit patterns stored in
    : eeprom
    : > pattern var byte
    : > do
    : > gosub getclockreading
    : > ' assume BCD, e.g. hrs.nib1=1, hrs.nib0=2 for 12 oclock
    : > read patterns+hours.nib1,pattern ' get the pattern from eeprom
    : > digit=hours10 ' showdigit takes pattern and digit as input
    : > gosub showdigit ' 10s of hours
    : > read patterns+hours.nib0,pattern ' get the pattern
    : > digit=hours1
    : > gosub showdigit ' 1s of hours
    : > ' and so on for all the digits
    : > ' it might be possible to reduce this to one for-next loop
    : > ' if the digits are well placed consecutively in RAM.
    : > loop
    : > -- Tracy
    : > To UNSUBSCRIBE, just send mail to:
    : > basicstamps-unsubscribe@yahoogroups.com
    : > from the same email address that you subscribed. Text in the Subject and
    : Body of the message will be ignored.
    : > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    of the
    Leroy,
    I saw that site. It was funny, as I had a partially dissassembled clock of
    the same type on my desk when I found it. I do plan to look at it some more
    to figure out extracting the date.
    Not much information about the acuostic laser, pretty new stuff. I made the
    ones you saw from that article you read, and that was all I found. I still
    have a couple pieces of substrate, if you want one.
    Jonathan
    www.madlabs.info
    Sent: Sunday, February 02, 2003 10:18 AM
    > Dear Jonathan,
    > or
    > for your clock..
    sound
    easier to
    > Leroy
    > From: "Jonathan Peakall" <jpeakall@m...>
    was
    the
    > : Jonathan
    > : www.madlabs.info
    > : > > I will be
    i.e.:
    > : hrs_Low,
    > : > >etc.
    > : > Hi Jonathan,
    > : > '{$PBASIC 2.5}
    > : eeprom
    > : > do
    > : > digit=hours1
    > : > loop
    > : > -- Tracy
    and
    and Body of the
