printer driver
Has anyone ever attempted to operate PC printer from a
stamp? This would be very interesting to me. Do PC
printers accept standard ASCII codes in parallel
format?
Scott
__________________________________________________
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
http://mailplus.yahoo.com
format?
Scott
Do you Yahoo!?
require a good number of pins. However, many cheap printers now don't
really accept ASCII. They do most of their work in a Windows driver and
just send codes to drive the print head over the connection. A
postscript printer (serial) and a Stamp could do some amazing things I
imagine.
Al Williams
AWC
* Limit monitor 8 channels at once
http://www.al-williams.com/awce/pak10.htm
Original Message
> From: Scott Sutton [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=OASxUYdAnya7NrfmAxXz5RKO6_kMOvr-dgeqQLTfBA2MNmzGzYNhRtnXhk9oEeU8l1yy8n1E6lWrSD4Ke69EBLg]scottsutton67@y...[/url
> Sent: Tuesday, January 28, 2003 1:25 PM
> To: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] printer driver
> format?
> Thanks
> Scott
> Do you Yahoo!?
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the
> Subject and Body of the message will be ignored.
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
>format?
Scott,
You might have a look at our EDE1400 Printer Interface IC. It receives
2400 Baud serial data and controls the standard Centronics bus to print
what it receives. A datasheet can be downloaded from www.elabinc.com
-Todd Peterson
E-Lab Digital Engineering, Inc.
www.elabinc.com (816) 257-9954
register to keep from tying up so many Stamp pins though.
If you need simple, get an Epson LX300+ -- they do serial and parallel and
are under $200. They are industrial quality narrow carriage dot matrix
though.
Original Message
> format?
