printer driver — Parallax Forums
printer driver
edited 2003-01-28 23:38 in General Discussion
Has anyone ever attempted to operate PC printer from a
stamp? This would be very interesting to me. Do PC
printers accept standard ASCII codes in parallel
format?
Scott
__________________________________________________
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
http://mailplus.yahoo.com
    edited 2003-01-28 19:27
    Some do and some don't. Serial printers are easiest. Parallel printers
    require a good number of pins. However, many cheap printers now don't
    really accept ASCII. They do most of their work in a Windows driver and
    just send codes to drive the print head over the connection. A
    postscript printer (serial) and a Stamp could do some amazing things I
    imagine.
    Al Williams
    AWC
    * Limit monitor 8 channels at once
    http://www.al-williams.com/awce/pak10.htm
    > From: Scott Sutton [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=OASxUYdAnya7NrfmAxXz5RKO6_kMOvr-dgeqQLTfBA2MNmzGzYNhRtnXhk9oEeU8l1yy8n1E6lWrSD4Ke69EBLg]scottsutton67@y...[/url
    > Sent: Tuesday, January 28, 2003 1:25 PM
    > Subject: [noparse][[/noparse]basicstamps] printer driver
    > format?
    > Thanks
    > Scott
    > Do you Yahoo!?
    > from the same email address that you subscribed. Text in the
    edited 2003-01-28 21:22
    >format?
    Scott,
    You might have a look at our EDE1400 Printer Interface IC. It receives
    2400 Baud serial data and controls the standard Centronics bus to print
    what it receives. A datasheet can be downloaded from www.elabinc.com
    -Todd Peterson
    E-Lab Digital Engineering, Inc.
    www.elabinc.com (816) 257-9954
    Should be pretty easy -- I would use some sort of parallel-output shift
    register to keep from tying up so many Stamp pins though.
    If you need simple, get an Epson LX300+ -- they do serial and parallel and
    are under $200. They are industrial quality narrow carriage dot matrix
    though.
    > format?
