ta7259p
Anyone know where I can find a data sheet on a ta7259p? Did a google search and
looked on
the Toshiba website and could not find.
thanks,
Leroy
looked on
thanks,
Leroy
useless. Have you tried to cross it to an NTE part number?. I often do that
to get a rough idea of function, pin out and electrical specs.
obsolete. However, national semiconductor has a replacement device,
which is also obsolete. Here is the datasheet on that:
http://www.national.com/pf/LM/LM325.html
Is this the right device?
google search and looked on
> thanks,
> Leroy
possible. After
your suggestion however, I did take a look but found nothing. What is the
Electronics
world coming to? I went directly to the Toshiba website and did a search for
that part
number with no result, unless you consider, "part not found" a result. However,
thanks
for the attemp and the reply.
Leroy
: I also need data on a Toshiba part TA7179P. Their web site is essentially
: useless. Have you tried to cross it to an NTE part number?. I often do that
: to get a rough idea of function, pin out and electrical specs.
: [noparse][[/noparse]Non-text portions of this message have been removed]
: To UNSUBSCRIBE, just send mail to:
: basicstamps-unsubscribe@yahoogroups.com
: from the same email address that you subscribed. Text in the Subject and Body
of the
message will be ignored.
: Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
many years ago but we kept a large library of technical books, maybe they
can help.
Todd
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Monday, January 27, 2003 1:57 PM
Subject: [noparse][[/noparse]basicstamps] ta7259p
> thanks,
> Leroy
http://www.newark.com/NewarkWebCommerce/newark/en_US/support
/catalog/productDetail.jsp?id=37C3436
Original Message
Sent: January 27, 2003 4:24 PM
Subject: Re: [noparse][[/noparse]basicstamps] ta7259p
: Actually I forgot that a cross on the NTE chip cross
reference might be possible. After
: your suggestion however, I did take a look but found
nothing. What is the Electronics
: world coming to? I went directly to the Toshiba website
and did a search for that part
: number with no result, unless you consider, "part not
found" a result. However, thanks
: for the attemp and the reply.
: Leroy
: : I also need data on a Toshiba part TA7179P. Their web
site is essentially
: : useless. Have you tried to cross it to an NTE part
: : to get a rough idea of function, pin out and electrical
specs.
: : [noparse][[/noparse]Non-text portions of this message have been removed]
: : To UNSUBSCRIBE, just send mail to:
: : basicstamps-unsubscribe@yahoogroups.com
: : from the same email address that you subscribed. Text
in the Subject and Body of the
: message will be ignored.
: : Your use of Yahoo! Groups is subject to
the Subject and Body of the message will be ignored.
I have found several places I can buy them, but I can't find a data sheet..
Appreciate
your looking though !! Actually I have one already, I wanted to hook it up to
the stamp
for fun but I doubt for profit [noparse]:)[/noparse] I took it out of an HP LASER JET III printer
I scraped
last week. Also took out the laser, kinda neat but I am afraid it Infra red..
Leroy
Original Message
Sent: Monday, January 27, 2003 8:55 PM
: Motor driver Ic newark has them in stock
: http://www.newark.com/NewarkWebCommerce/newark/en_US/support
: /catalog/productDetail.jsp?id=37C3436
Original Message
: From: "Leroy Hall" <leroy@f...>
: To: <basicstamps@yahoogroups.com>
: Sent: January 27, 2003 4:24 PM
: Subject: Re: [noparse][[/noparse]basicstamps] ta7259p
: : Actually I forgot that a cross on the NTE chip cross
: reference might be possible. After
: : your suggestion however, I did take a look but found
: nothing. What is the Electronics
: : world coming to? I went directly to the Toshiba website
: and did a search for that part
: : number with no result, unless you consider, "part not
: found" a result. However, thanks
: : for the attemp and the reply.
: : Leroy
: : : I also need data on a Toshiba part TA7179P. Their web
: site is essentially
: : : useless. Have you tried to cross it to an NTE part
: number?. I often do that
: : : to get a rough idea of function, pin out and electrical
: specs.
: : : [noparse][[/noparse]Non-text portions of this message have been removed]
: : : To UNSUBSCRIBE, just send mail to:
: : : basicstamps-unsubscribe@yahoogroups.com
: : : from the same email address that you subscribed. Text
: in the Subject and Body of the
: : message will be ignored.
: : : Your use of Yahoo! Groups is subject to
: http://docs.yahoo.com/info/terms/
: : from the same email address that you subscribed. Text in
: the Subject and Body of the message will be ignored.
of the
77.pdf
Original Message
: Leroy
site is essentially
specs.
it has a cross to a sk7615 i have the pinout
let me know
ken magers
> ta7259p? Did a
> > thanks,
> > Leroy
> Text in the Subject and Body of the message will be
> ignored.
__________________________________________________
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
http://mailplus.yahoo.com
http://www.chipdocs.com/pndecoder/datasheets/TOS/TA7259P.html
> thanks,
> Leroy
the pdf for the td7259p motor driver chip
the other one is on there to everone might want to
save this because i had to dig thrue a couple of pages
of japanese to find it.
http://www.semicon.toshiba.co.jp/eng/search/ft_datasheet.html
ken magers
Do you Yahoo!?
Thanks so much for your help. Your answer not only provided the assistance I
needed, but
also provided info on other part numbers from the company. Those of you that
did not pick
up on this might want to bookmark the link for future reference. Might come in
handy for
info on Toshiba Products info.
thanks again to Ken and all the other fine responses to my posting..
Leroy
Original Message
Sent: Tuesday, January 28, 2003 11:23 AM
: ok here is toshiba's data sheet site i just downloaded
: the pdf for the td7259p motor driver chip
: the other one is on there to everone might want to
: save this because i had to dig thrue a couple of pages
: of japanese to find it.
: http://www.semicon.toshiba.co.jp/eng/search/ft_datasheet.html
: ken magers
: __________________________________________________
: Do you Yahoo!?
: Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
: http://mailplus.yahoo.com
of the
Leroy
Original Message
Sent: Tuesday, January 28, 2003 5:04 AM
: Look at
: http://www.chipdocs.com/pndecoder/datasheets/TOS/TA7259P.html
: > Anyone know where I can find a data sheet on a ta7259p? Did a google
: search and looked on
: > the Toshiba website and could not find.
: > thanks,
: > Leroy
: > To UNSUBSCRIBE, just send mail to:
: > basicstamps-unsubscribe@yahoogroups.com
: > from the same email address that you subscribed. Text in the Subject and
: Body of the message will be ignored.
: > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
of the
Leroy
Original Message
Original Message
: : Leroy
: specs.
of the
