ta7259p — Parallax Forums
ta7259p
edited 2003-01-28 23:01 in General Discussion
Anyone know where I can find a data sheet on a ta7259p? Did a google search and
looked on
the Toshiba website and could not find.
thanks,
Leroy
    edited 2003-01-27 21:13
    I also need data on a Toshiba part TA7179P. Their web site is essentially
    useless. Have you tried to cross it to an NTE part number?. I often do that
    to get a rough idea of function, pin out and electrical specs.
    edited 2003-01-27 22:12
    I did a little search on yahoo. It appears that the device is
    obsolete. However, national semiconductor has a replacement device,
    which is also obsolete. Here is the datasheet on that:
    http://www.national.com/pf/LM/LM325.html
    Is this the right device?
    google search and looked on
    > thanks,
    > Leroy
    edited 2003-01-28 00:24
    Actually I forgot that a cross on the NTE chip cross reference might be
    possible. After
    your suggestion however, I did take a look but found nothing. What is the
    Electronics
    world coming to? I went directly to the Toshiba website and did a search for
    that part
    number with no result, unless you consider, "part not found" a result. However,
    thanks
    for the attemp and the reply.
    Leroy
    : I also need data on a Toshiba part TA7179P. Their web site is essentially
    : useless. Have you tried to cross it to an NTE part number?. I often do that
    : to get a rough idea of function, pin out and electrical specs.
    : [noparse][[/noparse]Non-text portions of this message have been removed]
    : To UNSUBSCRIBE, just send mail to:
    : basicstamps-unsubscribe@yahoogroups.com
    : from the same email address that you subscribed. Text in the Subject and Body
    of the
    message will be ignored.
    : Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    edited 2003-01-28 00:35
    Contact MCM Electronics Technical support 1-800-543-4330. I worked there
    many years ago but we kept a large library of technical books, maybe they
    can help.
    Todd
    Sent: Monday, January 27, 2003 1:57 PM
    Subject: [noparse][[/noparse]basicstamps] ta7259p
    > thanks,
    > Leroy
    edited 2003-01-28 01:55
    Motor driver Ic newark has them in stock
    http://www.newark.com/NewarkWebCommerce/newark/en_US/support
    /catalog/productDetail.jsp?id=37C3436
    Sent: January 27, 2003 4:24 PM
    Subject: Re: [noparse][[/noparse]basicstamps] ta7259p
    : Actually I forgot that a cross on the NTE chip cross
    reference might be possible. After
    : your suggestion however, I did take a look but found
    nothing. What is the Electronics
    : world coming to? I went directly to the Toshiba website
    and did a search for that part
    : number with no result, unless you consider, "part not
    found" a result. However, thanks
    : for the attemp and the reply.
    : Leroy
    : : I also need data on a Toshiba part TA7179P. Their web
    site is essentially
    : : useless. Have you tried to cross it to an NTE part
    : : to get a rough idea of function, pin out and electrical
    specs.
    : : [noparse][[/noparse]Non-text portions of this message have been removed]
    : : To UNSUBSCRIBE, just send mail to:
    : : basicstamps-unsubscribe@yahoogroups.com
    : : from the same email address that you subscribed. Text
    in the Subject and Body of the
    : message will be ignored.
    : : Your use of Yahoo! Groups is subject to
    the Subject and Body of the message will be ignored.
    edited 2003-01-28 02:11
    Thanks Larry,
    I have found several places I can buy them, but I can't find a data sheet..
    Appreciate
    your looking though !! Actually I have one already, I wanted to hook it up to
    the stamp
    for fun but I doubt for profit [noparse]:)[/noparse] I took it out of an HP LASER JET III printer
    I scraped
    last week. Also took out the laser, kinda neat but I am afraid it Infra red..
    Leroy
    Sent: Monday, January 27, 2003 8:55 PM
    : Motor driver Ic newark has them in stock
    : http://www.newark.com/NewarkWebCommerce/newark/en_US/support
    : /catalog/productDetail.jsp?id=37C3436
    : From: "Leroy Hall" <leroy@f...>
    : To: <basicstamps@yahoogroups.com>
    : Sent: January 27, 2003 4:24 PM
    : Subject: Re: [noparse][[/noparse]basicstamps] ta7259p
    : : Actually I forgot that a cross on the NTE chip cross
    : reference might be possible. After
    : : your suggestion however, I did take a look but found
    : nothing. What is the Electronics
    : : world coming to? I went directly to the Toshiba website
    : and did a search for that part
    : : number with no result, unless you consider, "part not
    : found" a result. However, thanks
    : : for the attemp and the reply.
    : : Leroy
    : : : I also need data on a Toshiba part TA7179P. Their web
    : site is essentially
    : : : useless. Have you tried to cross it to an NTE part
    : number?. I often do that
    : : : to get a rough idea of function, pin out and electrical
    : specs.
    : : : [noparse][[/noparse]Non-text portions of this message have been removed]
    : : : To UNSUBSCRIBE, just send mail to:
    : : : basicstamps-unsubscribe@yahoogroups.com
    : : : from the same email address that you subscribed. Text
    : in the Subject and Body of the
    : : message will be ignored.
    : : : Your use of Yahoo! Groups is subject to
    : http://docs.yahoo.com/info/terms/
    : : from the same email address that you subscribed. Text in
    : the Subject and Body of the message will be ignored.
    of the
    edited 2003-01-28 02:35
    http://www.freetradezone.com/design_center/images/pdf/D81068
    77.pdf
    : Leroy
    site is essentially
    specs.
    edited 2003-01-28 05:08
    are you needing complete data or just the pinout
    it has a cross to a sk7615 i have the pinout
    let me know
    ken magers
    > ta7259p? Did a
    > > thanks,
    > > Leroy
    > Text in the Subject and Body of the message will be
    > ignored.
    __________________________________________________
    Do you Yahoo!?
    Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
    http://mailplus.yahoo.com
    edited 2003-01-28 10:04
    Look at
    http://www.chipdocs.com/pndecoder/datasheets/TOS/TA7259P.html
    > thanks,
    > Leroy
    edited 2003-01-28 16:23
    ok here is toshiba's data sheet site i just downloaded
    the pdf for the td7259p motor driver chip
    the other one is on there to everone might want to
    save this because i had to dig thrue a couple of pages
    of japanese to find it.
    http://www.semicon.toshiba.co.jp/eng/search/ft_datasheet.html
    ken magers
    Do you Yahoo!?
    edited 2003-01-28 22:58
    Dear Ken,
    Thanks so much for your help. Your answer not only provided the assistance I
    needed, but
    also provided info on other part numbers from the company. Those of you that
    did not pick
    up on this might want to bookmark the link for future reference. Might come in
    handy for
    info on Toshiba Products info.
    thanks again to Ken and all the other fine responses to my posting..
    Leroy
    Sent: Tuesday, January 28, 2003 11:23 AM
    : ok here is toshiba's data sheet site i just downloaded
    : the pdf for the td7259p motor driver chip
    : the other one is on there to everone might want to
    : save this because i had to dig thrue a couple of pages
    : of japanese to find it.
    : http://www.semicon.toshiba.co.jp/eng/search/ft_datasheet.html
    : ken magers
    : __________________________________________________
    : Do you Yahoo!?
    : Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
    : http://mailplus.yahoo.com
    of the
    edited 2003-01-28 23:00
    Thanks for your input Michalis..
    Leroy
    Sent: Tuesday, January 28, 2003 5:04 AM
    : Look at
    : http://www.chipdocs.com/pndecoder/datasheets/TOS/TA7259P.html
    : > Anyone know where I can find a data sheet on a ta7259p? Did a google
    : search and looked on
    : > the Toshiba website and could not find.
    : > thanks,
    : > Leroy
    : > To UNSUBSCRIBE, just send mail to:
    : > basicstamps-unsubscribe@yahoogroups.com
    : > from the same email address that you subscribed. Text in the Subject and
    : Body of the message will be ignored.
    : > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    of the
    Thanks Larry !!!!!!!!!!!!
    Leroy
    : : Leroy
    : specs.
    of the
