help on SERIN/SEROUT
Hi All,
I'm quite a newbie in BasicStamp stuff.
At the moment I'm able to control all the functions I need for my
experiments, except the serial comms using serin/serout.
I'm using a BS2p (and also a bs2p 40 pin), and I've tried everything
to control basic I/O, without success.
Is there someone that can give a little help?
Below is a simple example that I'm not able to control:
'{$STAMP BS2p}
char var byte
debug cls
loop:
debug CR, "Ok" , CR
serin 16,18447,[noparse][[/noparse]char] 'recebe um caracter
serout 16,18447, [noparse][[/noparse]char] 'transmite o caracter
goto loop
it is suposed that for each char I sent (using debug terminal window),
it will be sent back, together with a CR and an "OK" prompt, right?
Well, it doesn't work...
I've already tried with and without ATN pin connected, and started at
9600bps, down to 1200bps.
Also tried INVERTED and Non INVERTED, without success.
I would appreciate your kind help.
Paulo
'{$STAMP BS2p}
char var byte
debug cls
loop:
debug CR, "Ok" , CR
goto loop
Paulo
jpcarvalhal@m... writes:
> char var byte
> debug cls
> loop:
> debug CR, "Ok" , CR
> goto loop
You are going to fast. Put a pause 1000 after the serout and then you will
be able to see it.
Sid Weaver
W4EKQ
Port Richey, FL
aux set of pins, you need to tell the device to use them..."AUXIO" is the
command to switch to tose pins...
The next problem is you never tell DEBUG to display the data U inout or
output..
Try this:
'{$STAMP BS2p}
> char var byte
> debug cls
> auxio
> loop:
> debug CR, "Ok" , CR
Debug str(char)
> goto loop
ALso, if the data is messed up try using 2063 as the baudmode incase your
device is sending that instead of inverted..
Mike B.
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Sunday, January 26, 2003 2:37 PM
Subject: [noparse][[/noparse]basicstamps] help on SERIN/SEROUT
> Hi All,
> '{$STAMP BS2p}
> char var byte
> debug cls
> loop:
> debug CR, "Ok" , CR
> goto loop
> Regards,
> Paulo
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
DEBUG statements send data to your PC at 9600 baud, 8 bits, no
parity, inverted. You should do the same when SEROUT or SERIN to or
from I/O 16, since that is what the DEBUG window typically expects.
Try baud value 16624 for the '2p.
You could help yourself by inserting
DEBUG CR, char
after your SERIN statement to verify what your Stamp received and
that execution has reached that point.
Steve
which is fixed to 9600 bits/s, 8 bits, no parity, 1 stop bit.
No matter what you try to set up with serin/serout the physical
parameters of port 16 remain the same.
Someone states that you should switch to AUXIO - well that is not
the point, port 16 corresponds to Rx/Tx, no matter whether after
AUXIO or MAINIO.
Regards
Adrian
sound every ten seconds or so)
That's a damn hard one to beat, it gets in to EVERYTHING!!
Original Message
Sent: Monday, January 27, 2003 7:28 PM
Subject: [noparse][[/noparse]basicstamps] Re: help on SERIN/SEROUT
> There is another point beside all the others: you use port 16
> AUXIO or MAINIO.
> Regards
> Adrian
Thank you for your help.
After a lot of unsuccessfull tests I messed up everything.
It's working!!! Yes!
Regards
Paulo
Mensagem original
De: S Parkis [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0bo4A5EkPTZ1GJ8CILQVuwmd39lbZXOkj6ALFJ4XN_5o9tkVxPo-u9F4nCQ_ISl8NFN7FdlEvLgpS6gp_8c]parkiss@e...[/url
Enviada: segunda-feira, 27 de Janeiro de 2003 1:04
Para: basicstamps@yahoogroups.com
Assunto: Re: [noparse][[/noparse]basicstamps] help on SERIN/SEROUT
Paulo-
DEBUG CR, char
Steve
Among other things I was trying to use port 16 with a baud diferent from
9600...
It's cool now!
Thank you.
Paulo
Mensagem original
De: Adrian Schneider <adrian.schneider@t...>
[noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=jN_tzdALOGE_JQmiSU8nMZf261oSmd4xV4EZnplR1b7CKe6tryMhCnynXzfGhEXPwyFuwjZFUGJLy2RSW2SpNMpxFmSG]adrian.schneider@t...[/url
Enviada: segunda-feira, 27 de Janeiro de 2003 8:28
Assunto: [noparse][[/noparse]basicstamps] Re: help on SERIN/SEROUT
AUXIO or MAINIO.
Regards
Adrian
Anyway I think I was ready to evaluate the probability of interference from
the microwave oven next door!
Thank you Dwain.
PAulo
Mensagem original
De: Dwain J. Hill [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Z7ro3lAbB279FWI-yF9Y0se7HZDV4fWqFwatTD6e0552lF6VlThVP3w1zMThqTZm7ObrjvrkZjkLX6T3QGlEmwY]dwainsworld@e...[/url
Enviada: segunda-feira, 27 de Janeiro de 2003 12:33
Assunto: Re: [noparse][[/noparse]basicstamps] Re: help on SERIN/SEROUT
Are you getting interference from the airports radar? (that would be a ZING
Original Message
> AUXIO or MAINIO.
> Regards
> Adrian
