help on SERIN/SEROUT — Parallax Forums
edited 2003-01-28 00:10 in General Discussion
Hi All,
I'm quite a newbie in BasicStamp stuff.
At the moment I'm able to control all the functions I need for my
experiments, except the serial comms using serin/serout.
I'm using a BS2p (and also a bs2p 40 pin), and I've tried everything
to control basic I/O, without success.
Is there someone that can give a little help?
Below is a simple example that I'm not able to control:
'{$STAMP BS2p}
char var byte
debug cls
loop:
debug CR, "Ok" , CR
serin 16,18447,[noparse][[/noparse]char] 'recebe um caracter
serout 16,18447, [noparse][[/noparse]char] 'transmite o caracter
goto loop
it is suposed that for each char I sent (using debug terminal window),
it will be sent back, together with a CR and an "OK" prompt, right?
Well, it doesn't work...
I've already tried with and without ATN pin connected, and started at
9600bps, down to 1200bps.
Also tried INVERTED and Non INVERTED, without success.
I would appreciate your kind help.
Paulo
    edited 2003-01-26 22:54
    In a message dated 01/26/2003 17:38:52 Eastern Standard Time,
    jpcarvalhal@m... writes:
    > char var byte
    > debug cls
    > loop:
    > debug CR, "Ok" , CR
    > goto loop
    You are going to fast. Put a pause 1000 after the serout and then you will
    be able to see it.
    Sid Weaver
    W4EKQ
    Port Richey, FL
    edited 2003-01-26 23:08
    I see a couple of problems.. First off the pin you have assigned is on the
    aux set of pins, you need to tell the device to use them..."AUXIO" is the
    command to switch to tose pins...
    The next problem is you never tell DEBUG to display the data U inout or
    output..
    Try this:
    '{$STAMP BS2p}
    > char var byte
    > debug cls
    > auxio
    > loop:
    > debug CR, "Ok" , CR
    Debug str(char)
    > goto loop
    ALso, if the data is messed up try using 2063 as the baudmode incase your
    device is sending that instead of inverted..
    Mike B.
    Sent: Sunday, January 26, 2003 2:37 PM
    Subject: [noparse][[/noparse]basicstamps] help on SERIN/SEROUT
    > Hi All,
    > '{$STAMP BS2p}
    > char var byte
    > debug cls
    > loop:
    > debug CR, "Ok" , CR
    > goto loop
    > Regards,
    > Paulo
    edited 2003-01-27 01:03
    Paulo-
    DEBUG statements send data to your PC at 9600 baud, 8 bits, no
    parity, inverted. You should do the same when SEROUT or SERIN to or
    from I/O 16, since that is what the DEBUG window typically expects.
    Try baud value 16624 for the '2p.
    You could help yourself by inserting
    DEBUG CR, char
    after your SERIN statement to verify what your Stamp received and
    that execution has reached that point.
    Steve
    edited 2003-01-27 08:28
    There is another point beside all the others: you use port 16
    which is fixed to 9600 bits/s, 8 bits, no parity, 1 stop bit.
    No matter what you try to set up with serin/serout the physical
    parameters of port 16 remain the same.
    Someone states that you should switch to AUXIO - well that is not
    the point, port 16 corresponds to Rx/Tx, no matter whether after
    AUXIO or MAINIO.
    Regards
    Adrian
    edited 2003-01-27 12:32
    Are you getting interference from the airports radar? (that would be a ZING
    sound every ten seconds or so)
    That's a damn hard one to beat, it gets in to EVERYTHING!!
    Sent: Monday, January 27, 2003 7:28 PM
    Subject: [noparse][[/noparse]basicstamps] Re: help on SERIN/SEROUT
    > AUXIO or MAINIO.
    > Regards
    > Adrian
    edited 2003-01-28 00:08
    Steve,
    Thank you for your help.
    After a lot of unsuccessfull tests I messed up everything.
    It's working!!! Yes!
    Regards
    Paulo
    Mensagem original
    De: S Parkis [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0bo4A5EkPTZ1GJ8CILQVuwmd39lbZXOkj6ALFJ4XN_5o9tkVxPo-u9F4nCQ_ISl8NFN7FdlEvLgpS6gp_8c]parkiss@e...[/url
    Enviada: segunda-feira, 27 de Janeiro de 2003 1:04
    Para: basicstamps@yahoogroups.com
    Assunto: Re: [noparse][[/noparse]basicstamps] help on SERIN/SEROUT
    Paulo-
    DEBUG CR, char
    Steve
    Adrian,
    Among other things I was trying to use port 16 with a baud diferent from
    9600...
    It's cool now!
    Thank you.
    Paulo
    Mensagem original
    De: Adrian Schneider <adrian.schneider@t...>
    [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=jN_tzdALOGE_JQmiSU8nMZf261oSmd4xV4EZnplR1b7CKe6tryMhCnynXzfGhEXPwyFuwjZFUGJLy2RSW2SpNMpxFmSG]adrian.schneider@t...[/url
    Enviada: segunda-feira, 27 de Janeiro de 2003 8:28
    Assunto: [noparse][[/noparse]basicstamps] Re: help on SERIN/SEROUT
    AUXIO or MAINIO.
    Regards
    Adrian
    No airports nearby.
    Anyway I think I was ready to evaluate the probability of interference from
    the microwave oven next door!
    Thank you Dwain.
    PAulo
    Mensagem original
    De: Dwain J. Hill [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Z7ro3lAbB279FWI-yF9Y0se7HZDV4fWqFwatTD6e0552lF6VlThVP3w1zMThqTZm7ObrjvrkZjkLX6T3QGlEmwY]dwainsworld@e...[/url
    Enviada: segunda-feira, 27 de Janeiro de 2003 12:33
    Assunto: Re: [noparse][[/noparse]basicstamps] Re: help on SERIN/SEROUT
    > AUXIO or MAINIO.
    > Regards
    > Adrian
