WOW - watch that static electricity
frustrated in this cold winter weather -- it's been in the single
digits and teens for days here and the static electricity has caused
havoc when programming both STAMPs and PIC's -- even knocked out our
ethernet connection for a while. I don't dare touch a MOSFET or a
CMOS chip without the wrist-strap.
if using the BOE, you can release the static on board if you have a
wrist-strap -- just momentarily touch the ground pin.
you may also build up a static charge on your serial cable and
connector just by getting close to it. same solution applies.
Jonathan
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Monday, January 20, 2003 8:15 AM
Subject: [noparse][[/noparse]basicstamps] WOW - watch that static electricity
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
