Pwm (0-5 v) to 0-15v
My project needs to multiply the StampII output
from 0 - 5 volts after PWM comand three times (3)
instead 0 - 5 volts to 0 -15 volts but with source 5 volts
or 9 volts
Knows someone if exist technicaly answer ?
Michalis
or 9 volts
Michalis
of charge pump the Stamp could PWM to get the higher output.
Original Message
> > or 9 volts
> If I understand your question, you have a PWM output that needs to
> swing between 0 and 15 volts but your only DC source is either 5 or 9
> volts. What I would suggest is a small DC-DC Boost converter to
> raise the 9 v to 15 or add another 9v battery. The Stamp output pin
> is then connected to an open-collector output inverter or buffer such
> as a 7407 or a simple transistor circuit with the output pulled up to
> 15v through a suitable resistor.
> or 9 volts
> Thanks
> Michalis
Hal
I yould like more specific details
the current is about 2 mA
Michalis
> If you only need very low current, you probably could come up with some
sort
Original Message
> > > or 9 volts
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
