Pwm (0-5 v) to 0-15v — Parallax Forums
edited 2003-01-12 17:39 in General Discussion
My project needs to multiply the StampII output
from 0 - 5 volts after PWM comand three times (3)
instead 0 - 5 volts to 0 -15 volts but with source 5 volts
or 9 volts
Knows someone if exist technicaly answer ?
Michalis
    edited 2003-01-12 13:54
    If you only need very low current, you probably could come up with some sort
    of charge pump the Stamp could PWM to get the higher output.
    > > or 9 volts
    > If I understand your question, you have a PWM output that needs to
    > swing between 0 and 15 volts but your only DC source is either 5 or 9
    > volts. What I would suggest is a small DC-DC Boost converter to
    > raise the 9 v to 15 or add another 9v battery. The Stamp output pin
    > is then connected to an open-collector output inverter or buffer such
    > as a 7407 or a simple transistor circuit with the output pulled up to
    > 15v through a suitable resistor.
    edited 2003-01-12 13:59
    --- In basicstamps@yahoogroups.com, "Michalis Vrakidis"
    > or 9 volts
    > Thanks
    > Michalis
    Hal
    Thanks for your answer but if you want
    I yould like more specific details
    the current is about 2 mA
    Michalis
    sort
    > > > or 9 volts
