Pulsout troubles
Happy new year to all,
My project is to make a robotic arm using modified servos.
The program that I wrote is the following:
input 0
high 0
input 1
high 1
get_status:
if in0 = 0 then up
if in1 = 0 then down
goto get_status
up:
low 2
pulsout 2 , 1000
pause 20
goto get_status
down:
low 2
pulsout 2 , 500
pause 20
goto get_status
The problem is that servos turning counterclockwise
eather I press the 1st button or I press the 2nd button.
What sould I do to make them turning both clockwise and
counterclockwise ?
Thank you,
Thomas
Do You Yahoo!?
input 0
high 0
input 1
high 1
get_status:
if in0 = 0 then up
goto get_status
up:
low 2
pulsout 2 , 1000
pause 20
goto get_status
down:
low 2
pulsout 2 , 500
pause 20
goto get_status
counterclockwise ?
Thank you,
Thomas
Do You Yahoo!?
"pulsout 2,500" should make it turn clockwise.
> input 0
> high 0
> input 1
> high 1
> get_status:
> if in0 = 0 then up
> goto get_status
> up:
> low 2
> pulsout 2 , 1000
> pause 20
> goto get_status
> down:
> low 2
> pulsout 2 , 500
> pause 20
> goto get_status
> counterclockwise ?
> Thank you,
> Thomas
> Do You Yahoo!?
(I had pullup resistors in series to buttons).
Note that both servos are modified to turn continuously
but with these commands they sould turn to both sides.
'Robotic arm project
Initialization
input 0 'Set P0 to input
input 1 'Set P1 to input
low 2 'Set P2 to output-low
Main routine
get_status:
if in0 = 0 then up
goto get_status
Full speed reverse
up: 'Turn counterclockwise
pulsout 2 , 500 'Send 1.0 ms pulses to P2
pause 20 'every 20 ms.
debug " arm up " 'Open the debug window and display arm up.
goto get_status 'Go to get_status
Full speed ahead
down: 'Turn clockwise
pulsout 2 , 1000 'Send 2.0 ms pulses to P2
debug " arm down " 'Open the debug window and display arm down.
Thanks again,
Thomas
Do You Yahoo!?
