Pulsout troubles — Parallax Forums
Pulsout troubles
edited 2003-01-06 18:38 in General Discussion
Happy new year to all,
My project is to make a robotic arm using modified servos.
The program that I wrote is the following:
input 0
high 0
input 1
high 1
get_status:
if in0 = 0 then up
if in1 = 0 then down
goto get_status
up:
low 2
pulsout 2 , 1000
pause 20
goto get_status
down:
low 2
pulsout 2 , 500
pause 20
goto get_status
The problem is that servos turning counterclockwise
eather I press the 1st button or I press the 2nd button.
What sould I do to make them turning both clockwise and
counterclockwise ?
Thank you,
Thomas
Do You Yahoo!?
    edited 2003-01-05 23:39
    "pulsout 2,1000" should make the servo turn counterclockwise.
    "pulsout 2,500" should make it turn clockwise.
    > input 0
    > high 0
    > input 1
    > high 1
    > get_status:
    > if in0 = 0 then up
    > goto get_status
    > up:
    > low 2
    > pulsout 2 , 1000
    > pause 20
    > goto get_status
    > down:
    > low 2
    > pulsout 2 , 500
    > pause 20
    > goto get_status
    > counterclockwise ?
    > Thank you,
    > Thomas
    > Do You Yahoo!?
    I rewrote the program with some changes but I still have problem.
    (I had pullup resistors in series to buttons).
    Note that both servos are modified to turn continuously
    but with these commands they sould turn to both sides.
    'Robotic arm project
    Initialization
    input 0 'Set P0 to input
    input 1 'Set P1 to input
    low 2 'Set P2 to output-low
    Main routine
    get_status:
    if in0 = 0 then up
    goto get_status
    Full speed reverse
    up: 'Turn counterclockwise
    pulsout 2 , 500 'Send 1.0 ms pulses to P2
    pause 20 'every 20 ms.
    debug " arm up " 'Open the debug window and display arm up.
    goto get_status 'Go to get_status
    Full speed ahead
    down: 'Turn clockwise
    pulsout 2 , 1000 'Send 2.0 ms pulses to P2
    debug " arm down " 'Open the debug window and display arm down.
    Thanks again,
    Thomas
    Do You Yahoo!?
