IR Buddy
Anyone using Parallax's IR Buddy yet? Im having problems getting the
RC-5 mode to work with assorted remote controls. It's doesn't look
like it's receiving anything. I'm sure it's something I'm doing
wrong.
wrong.
protocol is an older Philips protocol and may not be available on all your
remotes. I went to Wal*Mart and picked up a multifunction remote for 10
dollars. I set all the devices to Philips mode and found that only the TV
and VCR buttons would work; I suspect that the DVD and AUX channels are using
the newer RC-6 code [noparse][[/noparse]which requires licensing from Philips].
One of the demo programs that comes with the IR Buddy will show you received
RC-5 codes. You may need to try different Philips codes when programming
your remote to find the one that transmits RC-5; though I found that it was
usually the first on the list.
-- Jon Williams
-- Parallax
In a message dated 12/13/2002 6:02:29 AM Central Standard Time,
gtdesrosi@c... writes:
> wrong.
remotes (I'm using a X-10 multi deal) I did it on a standard PIC
(16F628 @ 4MHz) and a Radio Shack IR reciever. I used pulsin to
capture it and display the code on a serial LCD. The code *migth*
work on a STAMP (it was done in PIC Basic Pro) If you want the code
e-mail me off list) Weather it got RC-6 or RC-5 I dunno, but it got
and displayed whatever it was thrown at it. (double checked on a
scope)
--- In basicstamps@yahoogroups.com, "gtdesrosi <gtdesrosi@c...>"
the
> wrong.
I understand the IR Buddy will only work with RC-5 remotes. Is there a
way to determine if a remote is RC-5? I need to built an IR-to-IR
translater (Jerrold to General Instruments).
the documentation. If your remote is sending valid RC-5 codes, they'll show
up in the DEBUG window.
-- Jon Williams
-- Parallax
In a message dated 1/3/2003 8:12:58 PM Central Standard Time,
font_mark@y... writes:
> Jon,
