IR Buddy — Parallax Forums
IR Buddy
edited 2003-01-04 14:00 in General Discussion
Anyone using Parallax's IR Buddy yet? Im having problems getting the
RC-5 mode to work with assorted remote controls. It's doesn't look
like it's receiving anything. I'm sure it's something I'm doing
wrong.
    edited 2002-12-13 17:03
    I've used it quite a lot since I wrote the documentation for it. The RC-5
    protocol is an older Philips protocol and may not be available on all your
    remotes. I went to Wal*Mart and picked up a multifunction remote for 10
    dollars. I set all the devices to Philips mode and found that only the TV
    and VCR buttons would work; I suspect that the DVD and AUX channels are using
    the newer RC-6 code [noparse][[/noparse]which requires licensing from Philips].
    One of the demo programs that comes with the IR Buddy will show you received
    RC-5 codes. You may need to try different Philips codes when programming
    your remote to find the one that transmits RC-5; though I found that it was
    usually the first on the list.
    -- Jon Williams
    -- Parallax
    In a message dated 12/13/2002 6:02:29 AM Central Standard Time,
    gtdesrosi@c... writes:
    > wrong.
    edited 2002-12-13 22:31
    Not exactly on par here, but close. I had made a 'test stand' for
    remotes (I'm using a X-10 multi deal) I did it on a standard PIC
    (16F628 @ 4MHz) and a Radio Shack IR reciever. I used pulsin to
    capture it and display the code on a serial LCD. The code *migth*
    work on a STAMP (it was done in PIC Basic Pro) If you want the code
    e-mail me off list) Weather it got RC-6 or RC-5 I dunno, but it got
    and displayed whatever it was thrown at it. (double checked on a
    scope)
    --- In basicstamps@yahoogroups.com, "gtdesrosi <gtdesrosi@c...>"
    the
    > wrong.
    edited 2003-01-04 02:12
    Jon,
    I understand the IR Buddy will only work with RC-5 remotes. Is there a
    way to determine if a remote is RC-5? I need to built an IR-to-IR
    translater (Jerrold to General Instruments).
    edited 2003-01-04 04:36
    The best test would be to use the IR Code Explorer program that comes with
    the documentation. If your remote is sending valid RC-5 codes, they'll show
    up in the DEBUG window.
    -- Jon Williams
    -- Parallax
    In a message dated 1/3/2003 8:12:58 PM Central Standard Time,
    font_mark@y... writes:
    > Jon,
    Thanks Jon.
