ARRGH ! ADC problem ..
So I rise to the surface once again, but only because I am in trouble
[noparse]:([/noparse] I've hooked up an ADC to a Basic stamp. All the connections seem to
be ok and I'm just using the demo program that came with the LTC1298 (this
is an LTC1298 BTW).
The output just waves around all over the place but seem to regularly be
1024 2048 etc ... A test meter on the input pin say's it's stable at 2.5V
(the other is bound to the ground). Power supply is stable, ground is OK.
Any possible idea what could be wrong ?
Justin Pentecost Focus Puller -London
Tel:- 01491 826759 Fax:-01491 826655
justin@k...
CML Listpig
is an LTC1298 BTW).
justin@k...
CML Listpig
the voltage deviations. They're designed to show a steady voltage since we
all know that voltages are rarely actually steady. You'd need an ocilliscope
to see the variations.
Take a look at this message and others in its thread. Quite a few pointers:
http://groups.yahoo.com/group/basicstamps/message/26420
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Monday, December 09, 2002 1:41 PM
Subject: [noparse][[/noparse]basicstamps] ARRGH ! ADC problem ..
to
> is an LTC1298 BTW).
OK.
> justin@k...
> CML Listpig
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
What is your setup? What is providing input voltage, and what is providing
the ref voltage (VDD) to the LTC1298? I am using a LTC1298, and get
variations of about +/- 1-2, sometimes as high as 3. This is only using a
LM7805 as a regulator, better results can be had with a precision regulator.
Which I may switch to in my application because I have one, not because I
really need it. Do you have a cap across the power supply of the LTC1298?
Jonathan Peakall
www.madlabs.info
Original Message
to
> is an LTC1298 BTW).
OK.
> justin@k...
> CML Listpig
