ARRGH ! ADC problem .. — Parallax Forums
edited 2002-12-10 03:49 in General Discussion
So I rise to the surface once again, but only because I am in trouble
[noparse]:([/noparse] I've hooked up an ADC to a Basic stamp. All the connections seem to
be ok and I'm just using the demo program that came with the LTC1298 (this
is an LTC1298 BTW).
The output just waves around all over the place but seem to regularly be
1024 2048 etc ... A test meter on the input pin say's it's stable at 2.5V
(the other is bound to the ground). Power supply is stable, ground is OK.
Any possible idea what could be wrong ?
Justin Pentecost Focus Puller -London
Tel:- 01491 826759 Fax:-01491 826655
justin@k...
CML Listpig
    edited 2002-12-10 02:38
    Its most likely noisy power. A multimeter is not going to be able to show
    the voltage deviations. They're designed to show a steady voltage since we
    all know that voltages are rarely actually steady. You'd need an ocilliscope
    to see the variations.
    Take a look at this message and others in its thread. Quite a few pointers:
    http://groups.yahoo.com/group/basicstamps/message/26420
    Sent: Monday, December 09, 2002 1:41 PM
    Subject: [noparse][[/noparse]basicstamps] ARRGH ! ADC problem ..
    to
    > is an LTC1298 BTW).
    OK.
    > justin@k...
    > CML Listpig
    Justin,
    What is your setup? What is providing input voltage, and what is providing
    the ref voltage (VDD) to the LTC1298? I am using a LTC1298, and get
    variations of about +/- 1-2, sometimes as high as 3. This is only using a
    LM7805 as a regulator, better results can be had with a precision regulator.
    Which I may switch to in my application because I have one, not because I
    really need it. Do you have a cap across the power supply of the LTC1298?
    Jonathan Peakall
    www.madlabs.info
    to
    > is an LTC1298 BTW).
    OK.
    > justin@k...
    > CML Listpig
