Serial real-time with PC to BS2
Here's my BS2 code. This works as expected when I run it from the
BS2 editor and send the commands entered through the keyboard.
' {$STAMP BS2 }
PIN_CMD VAR BIT
Again:
TOGGLE 10
SERIN 16, 16468, 5000, NoData, [noparse][[/noparse]WAIT("cmd: "), DEC PIN_CMD]
DEBUG CLS, ? PIN_CMD
IF PIN_CMD = 1 THEN TurnOn
IF PIN_CMD = 0 THEN TurnOff
GOTO Again
TurnOn:
HIGH 0
DEBUG CLS, BIN1 IN0
GOTO Again
TurnOff:
LOW 0
DEBUG CLS, BIN1 IN0
GOTO Again
NoData:
DEBUG CR, "no data received"
GOTO Again
All I'm trying to do now, is to get any programming language to
interface with the serial port to do the control.
following is my matlab code.
>> s1 = serial('COM1', 'Baudrate', 9600)
Serial Port Object : Serial-COM1
Communication Settings
Port: COM1
BaudRate: 9600
Terminator: LF
Communication State
Status: closed
RecordStatus: off
Read/Write State
TransferStatus: idle
BytesAvailable: 0
ValuesReceived: 0
ValuesSent: 0
>> fopen(s1)
??? Error using ==> serial/fopen
Error using ==> fopen
Port: COM1 is not available. No ports are available.
Use INSTRFIND to determine if other instrument objects are connected
to the requested device.
>> instrfind
Instrument Object Array
Index: Type: Status: Name:
1 serial closed Serial-COM1
2 serial closed Serial-COM1
I've tried it w/ using a C++ serial port library, and it doesn't
work either. I'm not sure my library is any good, since it's just a
shareware version I found online. Do you know of any good but free
libraries around?
-Nigel
' {$STAMP BS2 }
PIN_CMD VAR BIT
Again:
TOGGLE 10
GOTO Again
TurnOn:
HIGH 0
DEBUG CLS, BIN1 IN0
GOTO Again
TurnOff:
LOW 0
DEBUG CLS, BIN1 IN0
GOTO Again
NoData:
GOTO Again
Port: COM1
BaudRate: 9600
Terminator: LF
Communication State
Status: closed
RecordStatus: off
Read/Write State
BytesAvailable: 0
ValuesReceived: 0
ValuesSent: 0
>> fopen(s1)
>> instrfind
libraries around?
-Nigel
posted to the files section on yahoo groups. I'm sure you can get the
matlab to do it too - I am no help there though.
mkl
Original Message
Date: Wednesday, November 27, 2002 10:45 am
Subject: [noparse][[/noparse]basicstamps] Serial real-time with PC to BS2
> ' {$STAMP BS2 }
> PIN_CMD VAR BIT
> Again:
> TOGGLE 10
> GOTO Again
> TurnOn:
> HIGH 0
> DEBUG CLS, BIN1 IN0
> GOTO Again
> TurnOff:
> LOW 0
> DEBUG CLS, BIN1 IN0
> GOTO Again
> NoData:
> GOTO Again
> Port: COM1
> BaudRate: 9600
> Terminator: LF
> Communication State
> Status: closed
> RecordStatus: off
> Read/Write State
> BytesAvailable: 0
> ValuesReceived: 0
> ValuesSent: 0
> >> fopen(s1)
> connected
> >> instrfind
> a
> free
> libraries around?
> -Nigel
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the
> Subject and Body of the message will be ignored.
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
control. And best of all, a Standard license is free to
home/education users.
I can give you help on using it for what you want too.
http://www.selmaware.com/stampplot
For example, you can read checkbox and control a BS2 output with:
DEBUG "!READ (CHK1)",CR
SERIN 84,16,[noparse][[/noparse]DEC PIN_CMD],CR
We've just posted a page with plenty of BS2 code discussions.
http://www.selmaware.com/stampPlot_v3/example_gen_use.htm
-Martin
> ' {$STAMP BS2 }
> PIN_CMD VAR BIT
> Again:
> TOGGLE 10
> GOTO Again
> TurnOn:
> HIGH 0
> DEBUG CLS, BIN1 IN0
> GOTO Again
> TurnOff:
> LOW 0
> DEBUG CLS, BIN1 IN0
> GOTO Again
> NoData:
> GOTO Again
> Port: COM1
> BaudRate: 9600
> Terminator: LF
> Communication State
> Status: closed
> RecordStatus: off
> Read/Write State
> BytesAvailable: 0
> ValuesReceived: 0
> ValuesSent: 0
> >> fopen(s1)
connected
> >> instrfind
a
> libraries around?
> -Nigel
but it is a little too wide to fit onto a page, what can I
do to print it correctly.
larry
Original Message
To: <basicstamps@yahoogroups.com>
Sent: November 27, 2002 9:22 AM
Subject: [noparse][[/noparse]basicstamps] Re: Serial real-time with PC to BS2
> Our StampPlot program can be used for real time data
acquisition and
output with:
discussions.
> -Martin
it from the
keyboard.
> > ' {$STAMP BS2 }
> > PIN_CMD VAR BIT
> > Again:
> > TOGGLE 10
PIN_CMD]
> > GOTO Again
> > TurnOn:
> > HIGH 0
> > DEBUG CLS, BIN1 IN0
> > GOTO Again
> > TurnOff:
> > LOW 0
> > DEBUG CLS, BIN1 IN0
> > GOTO Again
> > NoData:
> > GOTO Again
language to
> > Port: COM1
> > BaudRate: 9600
> > Terminator: LF
> > Communication State
> > Status: closed
> > RecordStatus: off
> > Read/Write State
> > BytesAvailable: 0
> > ValuesReceived: 0
> > ValuesSent: 0
> > >> fopen(s1)
are
> connected
> > >> instrfind
doesn't
it's just
> a
good but free
> > libraries around?
> > -Nigel
the Subject and Body of the message will be ignored.
Cleaned it up, thanks, try it again.
-Martin
--- In basicstamps@y..., "Larry Gaminde" <lgaminde@t...> wrote:
> This looks real nice Martin, I would like to print this out
> larry
Original Message
> From: "Martin Hebel" <martin@s...>
> To: <basicstamps@y...>
> acquisition and
> output with:
> discussions.
> > -Martin
> it from the
> keyboard.
> > > ' {$STAMP BS2 }
> > > PIN_CMD VAR BIT
> > > Again:
> > > TOGGLE 10
> PIN_CMD]
> > > GOTO Again
> > > TurnOn:
> > > HIGH 0
> > > DEBUG CLS, BIN1 IN0
> > > GOTO Again
> > > TurnOff:
> > > LOW 0
> > > DEBUG CLS, BIN1 IN0
> > > GOTO Again
> > > NoData:
> > > GOTO Again
> language to
> > > Port: COM1
> > > BaudRate: 9600
> > > Terminator: LF
> > > Communication State
> > > Status: closed
> > > RecordStatus: off
> > > Read/Write State
> > > BytesAvailable: 0
> > > ValuesReceived: 0
> > > ValuesSent: 0
> > > >> fopen(s1)
> are
> > connected
> > > >> instrfind
> doesn't
> it's just
> > a
> good but free
> > > libraries around?
> > > -Nigel
> > basicstamps-unsubscribe@y...
Larry
Original Message
Sent: November 27, 2002 11:17 AM
> Sorry about that, the image had pushed my borders out.
> -Martin
out
I
> > larry
Original Message
BS2
> > acquisition and
to
> > output with:
> > discussions.
> > > -Martin
run
> > it from the
> > keyboard.
> > > > ' {$STAMP BS2 }
> > > > PIN_CMD VAR BIT
> > > > Again:
> > > > TOGGLE 10
> > PIN_CMD]
> > > > GOTO Again
> > > > TurnOn:
> > > > HIGH 0
> > > > DEBUG CLS, BIN1 IN0
> > > > GOTO Again
> > > > TurnOff:
> > > > LOW 0
> > > > DEBUG CLS, BIN1 IN0
> > > > GOTO Again
> > > > NoData:
> > > > GOTO Again
> > language to
> > > > Port: COM1
> > > > BaudRate: 9600
> > > > Terminator: LF
> > > > Communication State
> > > > Status: closed
> > > > RecordStatus: off
> > > > Read/Write State
> > > > BytesAvailable: 0
> > > > ValuesReceived: 0
> > > > ValuesSent: 0
> > > > >> fopen(s1)
objects
> > are
> > > connected
> > > > >> instrfind
and it
> > doesn't
since
> > it's just
> > > a
any
> > good but free
> > > > libraries around?
> > > > -Nigel
in
