Serial real-time with PC to BS2 — Parallax Forums
edited 2002-11-27 23:23 in General Discussion
Here's my BS2 code. This works as expected when I run it from the
BS2 editor and send the commands entered through the keyboard.
' {$STAMP BS2 }
PIN_CMD VAR BIT
Again:
TOGGLE 10
SERIN 16, 16468, 5000, NoData, [noparse][[/noparse]WAIT("cmd: "), DEC PIN_CMD]
DEBUG CLS, ? PIN_CMD
IF PIN_CMD = 1 THEN TurnOn
IF PIN_CMD = 0 THEN TurnOff
GOTO Again
TurnOn:
HIGH 0
DEBUG CLS, BIN1 IN0
GOTO Again
TurnOff:
LOW 0
DEBUG CLS, BIN1 IN0
GOTO Again
NoData:
DEBUG CR, "no data received"
GOTO Again
All I'm trying to do now, is to get any programming language to
interface with the serial port to do the control.
following is my matlab code.
>> s1 = serial('COM1', 'Baudrate', 9600)
Serial Port Object : Serial-COM1
Communication Settings
Port: COM1
BaudRate: 9600
Terminator: LF
Communication State
Status: closed
RecordStatus: off
Read/Write State
TransferStatus: idle
BytesAvailable: 0
ValuesReceived: 0
ValuesSent: 0
>> fopen(s1)
??? Error using ==> serial/fopen
Error using ==> fopen
Port: COM1 is not available. No ports are available.
Use INSTRFIND to determine if other instrument objects are connected
to the requested device.
>> instrfind
Instrument Object Array
Index: Type: Status: Name:
1 serial closed Serial-COM1
2 serial closed Serial-COM1
I've tried it w/ using a C++ serial port library, and it doesn't
work either. I'm not sure my library is any good, since it's just a
shareware version I found online. Do you know of any good but free
libraries around?
-Nigel
    edited 2002-11-27 17:09
    Do you have Visual Basic? I know it works with VB and I have an example
    posted to the files section on yahoo groups. I'm sure you can get the
    matlab to do it too - I am no help there though.
    mkl
    Date: Wednesday, November 27, 2002 10:45 am
    Subject: [noparse][[/noparse]basicstamps] Serial real-time with PC to BS2
    > ' {$STAMP BS2 }
    > PIN_CMD VAR BIT
    > Again:
    > TOGGLE 10
    > GOTO Again
    > TurnOn:
    > HIGH 0
    > DEBUG CLS, BIN1 IN0
    > GOTO Again
    > TurnOff:
    > LOW 0
    > DEBUG CLS, BIN1 IN0
    > GOTO Again
    > NoData:
    > GOTO Again
    > Port: COM1
    > BaudRate: 9600
    > Terminator: LF
    > Communication State
    > Status: closed
    > RecordStatus: off
    > Read/Write State
    > BytesAvailable: 0
    > ValuesReceived: 0
    > ValuesSent: 0
    > >> fopen(s1)
    > connected
    > >> instrfind
    > a
    > free
    > libraries around?
    > -Nigel
    > from the same email address that you subscribed. Text in the
    edited 2002-11-27 17:22
    Our StampPlot program can be used for real time data acquisition and
    control. And best of all, a Standard license is free to
    home/education users.
    I can give you help on using it for what you want too.
    http://www.selmaware.com/stampplot
    For example, you can read checkbox and control a BS2 output with:
    DEBUG "!READ (CHK1)",CR
    SERIN 84,16,[noparse][[/noparse]DEC PIN_CMD],CR
    We've just posted a page with plenty of BS2 code discussions.
    http://www.selmaware.com/stampPlot_v3/example_gen_use.htm
    -Martin
    > ' {$STAMP BS2 }
    > PIN_CMD VAR BIT
    > Again:
    > TOGGLE 10
    > GOTO Again
    > TurnOn:
    > HIGH 0
    > DEBUG CLS, BIN1 IN0
    > GOTO Again
    > TurnOff:
    > LOW 0
    > DEBUG CLS, BIN1 IN0
    > GOTO Again
    > NoData:
    > GOTO Again
    > Port: COM1
    > BaudRate: 9600
    > Terminator: LF
    > Communication State
    > Status: closed
    > RecordStatus: off
    > Read/Write State
    > BytesAvailable: 0
    > ValuesReceived: 0
    > ValuesSent: 0
    > >> fopen(s1)
    connected
    > >> instrfind
    a
    > libraries around?
    > -Nigel
    edited 2002-11-27 18:46
    This looks real nice Martin, I would like to print this out
    but it is a little too wide to fit onto a page, what can I
    do to print it correctly.
    larry
    Sent: November 27, 2002 9:22 AM
    Subject: [noparse][[/noparse]basicstamps] Re: Serial real-time with PC to BS2
    acquisition and
    output with:
    discussions.
    > -Martin
    it from the
    keyboard.
    > > ' {$STAMP BS2 }
    > > PIN_CMD VAR BIT
    > > Again:
    > > TOGGLE 10
    PIN_CMD]
    > > GOTO Again
    > > TurnOn:
    > > HIGH 0
    > > DEBUG CLS, BIN1 IN0
    > > GOTO Again
    > > TurnOff:
    > > LOW 0
    > > DEBUG CLS, BIN1 IN0
    > > GOTO Again
    > > NoData:
    > > GOTO Again
    language to
    > > Port: COM1
    > > BaudRate: 9600
    > > Terminator: LF
    > > Communication State
    > > Status: closed
    > > RecordStatus: off
    > > Read/Write State
    > > BytesAvailable: 0
    > > ValuesReceived: 0
    > > ValuesSent: 0
    > > >> fopen(s1)
    are
    > connected
    > > >> instrfind
    doesn't
    it's just
    > a
    good but free
    > > libraries around?
    > > -Nigel
    the Subject and Body of the message will be ignored.
    edited 2002-11-27 19:17
    Sorry about that, the image had pushed my borders out.
    Cleaned it up, thanks, try it again.
    -Martin
    > larry
    > From: "Martin Hebel" <martin@s...>
    > To: <basicstamps@y...>
    > acquisition and
    > output with:
    > discussions.
    > > -Martin
    > it from the
    > keyboard.
    > > > ' {$STAMP BS2 }
    > > > PIN_CMD VAR BIT
    > > > Again:
    > > > TOGGLE 10
    > PIN_CMD]
    > > > GOTO Again
    > > > TurnOn:
    > > > HIGH 0
    > > > DEBUG CLS, BIN1 IN0
    > > > GOTO Again
    > > > TurnOff:
    > > > LOW 0
    > > > DEBUG CLS, BIN1 IN0
    > > > GOTO Again
    > > > NoData:
    > > > GOTO Again
    > language to
    > > > Port: COM1
    > > > BaudRate: 9600
    > > > Terminator: LF
    > > > Communication State
    > > > Status: closed
    > > > RecordStatus: off
    > > > Read/Write State
    > > > BytesAvailable: 0
    > > > ValuesReceived: 0
    > > > ValuesSent: 0
    > > > >> fopen(s1)
    > are
    > > connected
    > > > >> instrfind
    > doesn't
    > it's just
    > > a
    > good but free
    > > > libraries around?
    > > > -Nigel
    > > basicstamps-unsubscribe@y...
    Thanks so much, it printed just perfect.
    Larry
    Sent: November 27, 2002 11:17 AM
    > -Martin
    out
    I
    > > larry
    BS2
    > > acquisition and
    to
    > > output with:
    > > discussions.
    > > > -Martin
    run
    > > it from the
    > > keyboard.
    > > > > ' {$STAMP BS2 }
    > > > > PIN_CMD VAR BIT
    > > > > Again:
    > > > > TOGGLE 10
    > > PIN_CMD]
    > > > > GOTO Again
    > > > > TurnOn:
    > > > > HIGH 0
    > > > > DEBUG CLS, BIN1 IN0
    > > > > GOTO Again
    > > > > TurnOff:
    > > > > LOW 0
    > > > > DEBUG CLS, BIN1 IN0
    > > > > GOTO Again
    > > > > NoData:
    > > > > GOTO Again
    > > language to
    > > > > Port: COM1
    > > > > BaudRate: 9600
    > > > > Terminator: LF
    > > > > Communication State
    > > > > Status: closed
    > > > > RecordStatus: off
    > > > > Read/Write State
    > > > > BytesAvailable: 0
    > > > > ValuesReceived: 0
    > > > > ValuesSent: 0
    > > > > >> fopen(s1)
    objects
    > > are
    > > > connected
    > > > > >> instrfind
    and it
    > > doesn't
    since
    > > it's just
    > > > a
    any
    > > good but free
    > > > > libraries around?
    > > > > -Nigel
    in
