Controling a servo from VB
Hello
Can someone help a newbie?
I am trying to control a servo from Visual Basic. I dont seem to
understand how i shall receive the data from vb. The servo doesnt
behave any good( just jerks). Here is a sample of my code that i
have in the BS2.
'{$STAMP BS2}
output 1
tal var word
x var word
Main:
serin 16,16468,[noparse][[/noparse]wait (255),tal]
low 4
for x = 1 to 100
pulsout 1,tal
pause 10
next
high 4
serout 16,16780,[noparse][[/noparse]X]
goto main
have in the BS2.
'{$STAMP BS2}
output 1
tal var word
x var word
Main:
low 4
for x = 1 to 100
pulsout 1,tal
pause 10
next
high 4
goto main
might be called a poor mans high voltage controller or wanna-be x-10.
I stuck the servo arm into the switch box and fashioned a connector rod out
of a thick coat hanger, then drilled a hole in the arm on the switch to put
the connector rod thru. Result: Servo goes forward, lights/120vAc goes
out. Servo goes backward, lights/120v Ac goes on.
While this is no breakthru in electronics or power control - the cool thing
is I was able to fashion my own comm cable out of a long phone cord and a
male and female db9 connectors then hook the thing back to my PC and control
the switch from fairly far away using a simple VB app - all it has is an Up
button and a Down button on the GUI as well as an image of a light switch
that toggles up and down with the actual real light switch.
Again, I am totally new to this stuff and just doing a lot of guessing and
expirementing so don't take my code or project for any textbook examples.
I also realize I could make this project more dynamic by sending more data
from VB such as servo
position and having the stamp report back its position to verify it recd.
the command but there is so much to learn and the weekends are so short so i
just moved on from this project.
'***VB Code to send data to stamp
Private Sub cmdUp_Click()
comStamp.Output = "U"
imgLightSwitch.Picture = imgSwitchUp.Picture
End Sub
Private Sub cmdDown_Click()
comStamp.Output = "D"
imgLightSwitch.Picture = imgSwitchDown.Picture
End Sub
Private Sub Form_Load()
comStamp.CommPort = 1
comStamp.Settings = "2400,N,8,1"
comStamp.InputLen = 0
comStamp.PortOpen = True
End Sub
'***Stamp code to accept data from VB and control servo
'{$STAMP BS2}
'Description
'Program Controls Servo
'I/O defs
Servo con 0 'Servo Pin
'Varibales
Times VAR Byte
SerData VAR Byte
'Begin Program
Main:
serin 16,16780,[noparse][[/noparse]SerData]
if SerData = "U" then servo_up
if SerData = "D" then servo_down
GOTO Main
END
servo_up:
for Times = 0 to 100
PULSOUT Servo,(500) ' move the servo to up position
pause 5
next
return
servo_down:
PULSOUT Servo,(350) ' move the servo to up position
pause 5
next
return
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Sunday, November 24, 2002 4:10 AM
Subject: [noparse][[/noparse]basicstamps] Controling a servo from VB
> Hello
> have in the BS2.
> '{$STAMP BS2}
> output 1
> tal var word
> x var word
> Main:
> low 4
> for x = 1 to 100
> pulsout 1,tal
> pause 10
> next
> high 4
> goto main
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
--- In basicstamps@y..., Matt Lorenz <mklorenz@c...> wrote:
> I made a project that has a servo controlling a light switch. I
guess this
10.
rod out
switch to put
goes
cool thing
and a
and control
is an Up
switch
guessing and
examples.
more data
recd.
short so i
> End Sub
> End Sub
> End Sub
> '{$STAMP BS2}
> 'Description
> 'I/O defs
> 'Varibales
> Times VAR Byte
> SerData VAR Byte
> 'Begin Program
> Main:
> GOTO Main
> END
> servo_up:
> pause 5
> next
> return
> servo_down:
> pause 5
> next
> return
Original Message
> From: "gertlind" <gert.lindstrom@b...>
> To: <basicstamps@y...>
> > Hello
> > have in the BS2.
> > '{$STAMP BS2}
> > output 1
> > tal var word
> > x var word
> > Main:
> > low 4
> > for x = 1 to 100
> > pulsout 1,tal
> > pause 10
> > next
> > high 4
> > goto main
> > basicstamps-unsubscribe@y...
Subject and
to experiment with some settings in VB. Also, I think he fails to
mention that you need to setup a timer in VB to read values from your
PC's serial input.
www.picobay.com
hope it helps
--- In basicstamps@y..., "gertlind" <gert.lindstrom@b...> wrote:
> Hello
> have in the BS2.
> '{$STAMP BS2}
> output 1
> tal var word
> x var word
> Main:
> low 4
> for x = 1 to 100
> pulsout 1,tal
> pause 10
> next
> high 4
> goto main
You might try:
serin 16,16468,[noparse][[/noparse]wait (255), Dec tal]
You need this decimal formatter to tell it it is a number rather than ascii
text.
I tested it on a servo and without the Dec it indeed "twitches" but with the
Dec formatter the servo rolls to whatever number you send in from the VB
app.
Original Message
Sent: Monday, November 25, 2002 5:55 PM
Subject: [noparse][[/noparse]basicstamps] Re: Controling a servo from VB
> This guy has a good tutorial on how to do that... although you have
> PC's serial input.
> www.picobay.com
> hope it helps
> > Hello
> > have in the BS2.
> > '{$STAMP BS2}
> > output 1
> > tal var word
> > x var word
> > Main:
> > low 4
> > for x = 1 to 100
> > pulsout 1,tal
> > pause 10
> > next
> > high 4
> > goto main
