Controling a servo from VB — Parallax Forums
edited 2002-11-26 02:00 in General Discussion
Hello
Can someone help a newbie?
I am trying to control a servo from Visual Basic. I dont seem to
understand how i shall receive the data from vb. The servo doesnt
behave any good( just jerks). Here is a sample of my code that i
have in the BS2.
'{$STAMP BS2}
output 1
tal var word
x var word
Main:
serin 16,16468,[noparse][[/noparse]wait (255),tal]
low 4
for x = 1 to 100
pulsout 1,tal
pause 10
next
high 4
serout 16,16780,[noparse][[/noparse]X]
goto main
    edited 2002-11-24 14:21
    I made a project that has a servo controlling a light switch. I guess this
    might be called a poor mans high voltage controller or wanna-be x-10.
    I stuck the servo arm into the switch box and fashioned a connector rod out
    of a thick coat hanger, then drilled a hole in the arm on the switch to put
    the connector rod thru. Result: Servo goes forward, lights/120vAc goes
    out. Servo goes backward, lights/120v Ac goes on.
    While this is no breakthru in electronics or power control - the cool thing
    is I was able to fashion my own comm cable out of a long phone cord and a
    male and female db9 connectors then hook the thing back to my PC and control
    the switch from fairly far away using a simple VB app - all it has is an Up
    button and a Down button on the GUI as well as an image of a light switch
    that toggles up and down with the actual real light switch.
    Again, I am totally new to this stuff and just doing a lot of guessing and
    expirementing so don't take my code or project for any textbook examples.
    I also realize I could make this project more dynamic by sending more data
    from VB such as servo
    position and having the stamp report back its position to verify it recd.
    the command but there is so much to learn and the weekends are so short so i
    just moved on from this project.
    '***VB Code to send data to stamp
    Private Sub cmdUp_Click()
    comStamp.Output = "U"
    imgLightSwitch.Picture = imgSwitchUp.Picture
    End Sub
    Private Sub cmdDown_Click()
    comStamp.Output = "D"
    imgLightSwitch.Picture = imgSwitchDown.Picture
    End Sub
    Private Sub Form_Load()
    comStamp.CommPort = 1
    comStamp.Settings = "2400,N,8,1"
    comStamp.InputLen = 0
    comStamp.PortOpen = True
    End Sub
    '***Stamp code to accept data from VB and control servo
    '{$STAMP BS2}
    'Description
    'Program Controls Servo
    'I/O defs
    Servo con 0 'Servo Pin
    'Varibales
    Times VAR Byte
    SerData VAR Byte
    'Begin Program
    Main:
    serin 16,16780,[noparse][[/noparse]SerData]
    if SerData = "U" then servo_up
    if SerData = "D" then servo_down
    GOTO Main
    END
    servo_up:
    for Times = 0 to 100
    PULSOUT Servo,(500) ' move the servo to up position
    pause 5
    next
    return
    servo_down:
    PULSOUT Servo,(350) ' move the servo to up position
    pause 5
    next
    return
    Sent: Sunday, November 24, 2002 4:10 AM
    Subject: [noparse][[/noparse]basicstamps] Controling a servo from VB
    > Hello
    > have in the BS2.
    > '{$STAMP BS2}
    > output 1
    > tal var word
    > x var word
    > Main:
    > low 4
    > for x = 1 to 100
    > pulsout 1,tal
    > pause 10
    > next
    > high 4
    > goto main
    edited 2002-11-24 21:03
    Wow thats using overkill! [noparse]:)[/noparse] But hey it DOES work...
    guess this
    10.
    rod out
    switch to put
    goes
    cool thing
    and a
    and control
    is an Up
    switch
    guessing and
    examples.
    more data
    recd.
    short so i
    > End Sub
    > End Sub
    > End Sub
    > '{$STAMP BS2}
    > 'Description
    > 'I/O defs
    > 'Varibales
    > Times VAR Byte
    > SerData VAR Byte
    > 'Begin Program
    > Main:
    > GOTO Main
    > END
    > servo_up:
    > pause 5
    > next
    > return
    > servo_down:
    > pause 5
    > next
    > return
    > From: "gertlind" <gert.lindstrom@b...>
    > To: <basicstamps@y...>
    > > Hello
    > > have in the BS2.
    > > '{$STAMP BS2}
    > > output 1
    > > tal var word
    > > x var word
    > > Main:
    > > low 4
    > > for x = 1 to 100
    > > pulsout 1,tal
    > > pause 10
    > > next
    > > high 4
    > > goto main
    > > basicstamps-unsubscribe@y...
    Subject and
    edited 2002-11-25 23:55
    This guy has a good tutorial on how to do that... although you have
    to experiment with some settings in VB. Also, I think he fails to
    mention that you need to setup a timer in VB to read values from your
    PC's serial input.
    www.picobay.com
    hope it helps
    --- In basicstamps@y..., "gertlind" <gert.lindstrom@b...> wrote:
    > Hello
    > have in the BS2.
    > '{$STAMP BS2}
    > output 1
    > tal var word
    > x var word
    > Main:
    > low 4
    > for x = 1 to 100
    > pulsout 1,tal
    > pause 10
    > next
    > high 4
    > goto main
    You have:
    You might try:
    serin 16,16468,[noparse][[/noparse]wait (255), Dec tal]
    You need this decimal formatter to tell it it is a number rather than ascii
    text.
    I tested it on a servo and without the Dec it indeed "twitches" but with the
    Dec formatter the servo rolls to whatever number you send in from the VB
    app.
    Sent: Monday, November 25, 2002 5:55 PM
    Subject: [noparse][[/noparse]basicstamps] Re: Controling a servo from VB
    > PC's serial input.
    > www.picobay.com
    > hope it helps
    > > Hello
    > > have in the BS2.
    > > '{$STAMP BS2}
    > > output 1
    > > tal var word
    > > x var word
    > > Main:
    > > low 4
    > > for x = 1 to 100
    > > pulsout 1,tal
    > > pause 10
    > > next
    > > high 4
    > > goto main
