does the new windows editor adjust for the stamp in use?
hello,
When using the new editor, does it automatically
adjust for different processor speeds for things
like 'pause', 'pulsout', etc??
BASIC stamp editor v1.33
commands require adjustments to the parameters for each processor. Consult
the help file or manual for specifics.
-- Jon Williams
-- Parallax
In a message dated 11/8/02 5:47:34 AM Central Standard Time, rad0@a...
writes:
> hello,
Why is that? If pause command can compensate for processor speed, why have
other clock dependant commands not behave the same way? It seems strange
that you should have to look up baud rate parameters on a table for
different Stamp models.
At 08:45 AM 11/8/2002 -0500, you wrote:
>No. The PAUSE parameter is always specified in milliseconds, but other
>-- Jon Williams
_________________________________
Mike Walsh
walsh@i...
that saves some editing during migration. With other commands, the parameter
change allows the programmer to take advantage of better resolution (i.e.,
with PULSIN).
You can help yourself by minimizing what we call "magic numbers" -- numeric
values embedded in your code -- and replacing them with constant definitions.
This is especially helpful when you have the same value over and over. By
using constants, you can adjust your program from the definitions section
instead of hunting through the code.
-- Jon Williams
-- Parallax
In a message dated 11/8/02 9:24:05 AM Central Standard Time,
walsh@c... writes:
> Jon,
> Mike
