does the new windows editor adjust for the stamp in use? — Parallax Forums
edited 2002-11-08 15:30 in General Discussion
hello,
When using the new editor, does it automatically
adjust for different processor speeds for things
like 'pause', 'pulsout', etc??
BASIC stamp editor v1.33
    edited 2002-11-08 13:45
    No. The PAUSE parameter is always specified in milliseconds, but other
    commands require adjustments to the parameters for each processor. Consult
    the help file or manual for specifics.
    -- Jon Williams
    -- Parallax
    In a message dated 11/8/02 5:47:34 AM Central Standard Time, rad0@a...
    writes:
    > hello,
    edited 2002-11-08 15:21
    Jon,
    Why is that? If pause command can compensate for processor speed, why have
    other clock dependant commands not behave the same way? It seems strange
    that you should have to look up baud rate parameters on a table for
    different Stamp models.
    >-- Jon Williams
    _________________________________
    Mike Walsh
    walsh@i...
    PAUSE gets used far more frequently than other time dependent commands, so
    that saves some editing during migration. With other commands, the parameter
    change allows the programmer to take advantage of better resolution (i.e.,
    with PULSIN).
    You can help yourself by minimizing what we call "magic numbers" -- numeric
    values embedded in your code -- and replacing them with constant definitions.
    This is especially helpful when you have the same value over and over. By
    using constants, you can adjust your program from the definitions section
    instead of hunting through the code.
    -- Jon Williams
    -- Parallax
    In a message dated 11/8/02 9:24:05 AM Central Standard Time,
    walsh@c... writes:
    > Jon,
    > Mike
