max 3100 code samples...
anyone know of some code samples for the MAX 3100 that specifically
uses ShiftOut/ShiftIn? Actually, I am looking for input/output
register programming format tips along with an example of a 16-bit
data format (8 bits of 3100 control and 8 bits of data). I am
looking for another explanation that is different from the MAX 3100
data sheet..
Once I am successful, I'll be more than happy to post my results here
as MAX 3100 shiftin/out sample code.
data sheet..
>data sheet..
Jim -
Here is one use of the MAX3100 in an IrDA Application from Tracy Allen's
web site: http://www.emesystems.com/BS2IrDA.htm
That may get you started.
Bruce Bates
>To UNSUBSCRIBE, just send mail to:
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
for 30 minutes today unexpectedly, but they are up again. This is a 3110
but it should be about the same.
Al Williams
AWC
* Easy RS-232 Prototyping
http://www.al-williams.com/awce/rs1.htm
Original Message
> From: Jim Cambron [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=e8nPfQdnTcgA8aS7C1z0GfCGDbSF_MmoJjPp02pFYSnLpXcgzh0QOv9IWu-a8XOaXj5hP11SsZdDleulmrFWQ2njecUw]nehsoft@n...[/url
> Sent: Thursday, October 31, 2002 2:41 PM
> To: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] max 3100 code samples...
> data sheet..
> Subject and Body of the message will be ignored.
I posted a new diagram about the configuration word for the MAX3100
at http://www.emesystems.com/BS2IrDA.htm, near the bottom of the page
after the program listing.
It is easy to modify that program for a hardwired connection. Attach
a line driver to the tx and rx pins, instead of the LED and
photodetector, and turn off the IrDA bit in the configuration word.
-- regards
Tracy Allen
electronically monitored ecosystems
mailto:tracy@e...
>>data sheet..
>Jim -
>Regards,
>Bruce Bates
> Jim -
Allen's
> Regards,
> Bruce Bates
Excellent, Bruce! Exactly what I was looking for!
Thanks!
Jim
