max 3100 code samples... — Parallax Forums
edited 2002-11-02 17:59 in General Discussion
anyone know of some code samples for the MAX 3100 that specifically
uses ShiftOut/ShiftIn? Actually, I am looking for input/output
register programming format tips along with an example of a 16-bit
data format (8 bits of 3100 control and 8 bits of data). I am
looking for another explanation that is different from the MAX 3100
data sheet..
Once I am successful, I'll be more than happy to post my results here
as MAX 3100 shiftin/out sample code.
    edited 2002-10-31 20:59
    >data sheet..
    Jim -
    Here is one use of the MAX3100 in an IrDA Application from Tracy Allen's
    web site: http://www.emesystems.com/BS2IrDA.htm
    That may get you started.
    Bruce Bates
    >from the same email address that you subscribed. Text in the Subject and
    >Body of the message will be ignored.
    >Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    edited 2002-10-31 21:26
    Have a look at http://www.wd5gnr.com/suart.htm -- our sites were down
    for 30 minutes today unexpectedly, but they are up again. This is a 3110
    but it should be about the same.
    Al Williams
    AWC
    * Easy RS-232 Prototyping
    http://www.al-williams.com/awce/rs1.htm
    > From: Jim Cambron [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=e8nPfQdnTcgA8aS7C1z0GfCGDbSF_MmoJjPp02pFYSnLpXcgzh0QOv9IWu-a8XOaXj5hP11SsZdDleulmrFWQ2njecUw]nehsoft@n...[/url
    > Sent: Thursday, October 31, 2002 2:41 PM
    > Subject: [noparse][[/noparse]basicstamps] max 3100 code samples...
    > data sheet..
    edited 2002-11-01 19:52
    Hi Jim,
    I posted a new diagram about the configuration word for the MAX3100
    at http://www.emesystems.com/BS2IrDA.htm, near the bottom of the page
    after the program listing.
    It is easy to modify that program for a hardwired connection. Attach
    a line driver to the tx and rx pins, instead of the LED and
    photodetector, and turn off the IrDA bit in the configuration word.
    -- regards
    Tracy Allen
    mailto:tracy@e...
    >>data sheet..
    >Jim -
    >Regards,
    >Bruce Bates
    > Jim -
    Allen's
    > Regards,
    > Bruce Bates
    Excellent, Bruce! Exactly what I was looking for!
    Thanks!
    Jim
