I've posted a BS2 library that I created for Eagle in the "Files"
folder (groups.yahoo.com/group/basicstamps/files). This is my first
attempt at a library. Please let me know if it doesn't work!
-- Jeff Wallace
--{ www.high-techgarage.com }--
--{ Why park your STAMP anywhere else? }--
--- In basicstamps@y..., moretraction@a... wrote:
> Does anyone have a basicstamp sch. for eagle software.
I posted a BS2 library in the files section. It includes the
schematic and library.
Hope that helps.
-- Jeff Wallace
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
I've been using Orcad for years (under DOS, and without autorouter...
NO, I'm not THAT old ;-) ).
Then I've tried Eagle, because it was free and running under Windows.
I must say that I had to fight again myself to keep trying to use this
software, and forgeting all Ocad's quick keyboard shortcuts.
But now, I'm used to it, and I use it for all schematics I have to do
(also for electric diagrams).
You can create your own libraries with "exotic" components (new ICs,
motors, contactors, displays...)
The free version is fully operational, except for the following :
* the useable board area is limited to 100 x 80 mm (4 x 3.2
inches).
* only two signal layers can be used (Top and Bottom).
* the schematic editor can only create one sheet.
If you realy make your own PCB, two layers should be enough, and 100 x
80 mm is not so small.
I still use the 4.01 version, and I'm happy with this... but I don't
know PCB Express !
Phil.
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Tuesday, October 29, 2002 12:04 PM
Subject: Re: [noparse][[/noparse]basicstamps] Eagle ( was Re: best way to get PC boards
from ExpressPCB to a board house
| I tried Eagle also, and got nowhere. I downloaded the PCB Express
software
| and had a decent 2-layer board done in a couple of hours.
| > I think many of us have tired Eagle.
| > and most never got over the sheer cliff of a learning curve.
| > I would have hoped they would have come up with a tutorial
| > that made it easier to learn.
| > seems the buisness model of giveing away the low end
| > did not make it the beginners package.
Original Message
To: basicstamps@yahoogroups.com
Sent: Sunday, April 22, 2001 2:43 PM
Subject: [noparse][[/noparse]basicstamps] eagle
[font=arial,helvetica]Does anyone have a basicstamp sch. for eagle software.
[/font]
-- Jeff Wallace
Hope that helps.
-- Jeff Wallace
thanks[/font]
inches).
know PCB Express !
Phil.
Original Message
software
