New PBASIC Tokenizer Released Today
Hi,
We have just released the PBASIC Tokenizer for Macintosh (OS 9 and OS
X). It is a "carbonized" shared library that will run in both OS versions.
Additionally, due to feedback from the initial release, we made a
modification to the TModuleRec structure (the shared memory structure
required to interface to the tokenizer) in order to accomidate development
languages and platforms that impose limitations on fixed structures.
This means two things:
1) All the Visual BASIC users who gave up on the original release should
download this release.
2) Those that used the original (even in Linux) will need to make a
slight modification to their interface.
Please read the What's New section of the "Using the PBASIC Tokenizer
Library" document for more information.
You can download the latest release (supporting Windows, Linux and Mac) from:
http://www.parallaxinc.com/html_files/downloads/downloads_tokenizer.htm
or just go to http://www.parallaxinc.com and click on the link at the top
of the NEWS column.
Jeff Martin
Engineering Manager
Parallax, Inc
www.parallaxinc.com
www.stampsinclass.com
of the NEWS column.
Jeff Martin
Engineering Manager
Parallax, Inc
www.parallaxinc.com
going with RealBasic...
http://www.lennard.net.nz/
Ben Lennard, NCEE, Dip EE
Electronics R&D
Hm: +64 4 972 7567
Mb: +64 21 536 627
87 Spencer Street
Crofton Downs
Wellington
New Zealand
"To the optimist, the glass is half full. To the pessimist, the glass is
half empty. To the engineer, the glass is twice as big as it needs to be."
No animals were harmed in the transmission of this email, although the
Dog next door is living on borrowed time, let me tell you! Those of you
with an overwhelming fear of the unknown will be gratified to learn that
there is no hidden message revealed by reading this warning backwards.
> From: Jeff Martin <jmartin@p...>
> Reply-To: basicstamps@yahoogroups.com
> Date: Fri, 18 Oct 2002 17:09:43 -0700
> Subject: [noparse][[/noparse]basicstamps] New PBASIC Tokenizer Released Today
> Hi,
> of the NEWS column.
> Jeff Martin
> Engineering Manager
> Parallax, Inc
> www.parallaxinc.com
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and Body
> of the message will be ignored.
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
> Hi,
> of the NEWS column.
Is there some secret to accessing these files? I've been trying both of these
methods to access the latest tokenizer files, using 3 different browsers
(Netscape
on a SPARC and a PC, and IE on a PC) but all that comes up are the two,
PBASIC_Tokenizer.zip and PBASIC_Tokenizer.tar.gz, that contain files from back
in
September.
How does one get access to the latest versions mentioned in this posting, plus
the one for the Mac?
Any help would be appreciated!
Philip Restuccia
Philip Restuccia
Senior Principal Software Engineer
Nortel Networks
pjr89@n...
1) Go to the Parallax web site: www.parallaxinc.com
2) Right under the news banner (middle of screen), click the Tokenizer link.
3) You'll find the various platform links at the bottom of the page.
4) Right-click the desired archive link, then select "Save Target As..."
I work remotely (in Dallas, TX) and just tested this will all three archives.
My browser is IE 6.
-- Jon Williams
-- Parallax
In a message dated 10/21/02 2:50:57 PM Central Daylight Time,
pjr89@n... writes:
> plus
> See if this works for you:
Thanks for your prompt reply, Jon. Unfortunately, I had already tried this ...
but I tried again, just to be sure, and it still showed the same page, with the
same 2 links (for the Windows and Linux versions, and those contained files
dated
from September 2002).
In particular, when I download those files, I get this:
Archive: PBASIC_Tokenizer.zip
Length Method Size Ratio Date Time CRC-32 Name
221027 Defl:X 186607 16% 09-19-02 09:14 5d7bc80b Using the PBASIC
Tokenizer Library.pdf
196608 Defl:X 65079 67% 09-19-02 09:03 a584a221 Windows/tokenizer.dll
0 Stored 0 0% 09-19-02 09:07 00000000 Windows/
47728 Defl:X 38085 20% 09-19-02 09:10 e7a213ce BASIC Stamp
Programming Protocol v1.1.pdf
10218 Defl:X 7179 30% 09-19-02 09:10 534e112d PBASIC Tokenizer
Software Distribution License.pdf
84401 Defl:X 27378 68% 09-18-02 14:59 58a92c8e Linux/tokenizer.so
0 Stored 0 0% 09-19-02 09:08 00000000 Linux/
559982 324328 42% 7 files
for PBASIC_Tokenizer.zip, and:
-rwxrwxr-x jmartin/jmartin 47728 2002-09-19 12:22
Basic_Stamp_Programming_Protocol_v1.1.pdf
-rwxrwxr-x jmartin/jmartin 10218 2002-09-19 12:22
PBASIC_Tokenizer_Library_License.pdf
-rwxrwxr-x jmartin/jmartin 221027 2002-09-19 12:22
Using_The_PBASIC_Tokenizer_Library.pdf
drwxrwxr-x jmartin/jmartin 0 2002-09-19 12:30 linux/
-rwxrwxr-x jmartin/jmartin 84401 2002-09-19 12:23 linux/tokenizer.so
drwxrwxr-x jmartin/jmartin 0 2002-09-19 12:31 windows/
-rwxrwxr-x jmartin/jmartin 196608 2002-09-19 12:23 windows/tokenizer.dll
for PBASIC_Tokenizer.tar.gz.
Philip Restuccia
> My browser is IE 6.
> -- Jon Williams
> -- Parallax
> pjr89@n... writes:
> > plus
Philip Restuccia
Nortel Networks
pjr89@n...
>(Netscape
>back in
>September.
> Philip Restuccia
The files are there; I can see the links to them, but haven't downloaded
them since I don't have a MAC. Maybe you need to clear your browser cache
so you see the current copy of the web page vs the older one cached on your
system?
Jim H
browser. Perhaps you're getting a cached page.
-- Jon Williams
In a message dated 10/21/02 3:12:01 PM Central Daylight Time,
pjr89@n... writes:
> the
> dated
> >(Netscape
> >back in
> >September.
plus
> > Philip Restuccia
> system?
Tried that, too, Jim. On all 3 browsers I tried. One on a SPARC (Netscape 4.78)
and 2 on a PC (Netscape 6.2 and IE 5.5, which had NEVER been used to access the
Parallax site .. I avoid using M$ progs as much as possible, doing as much as I
possibly can on my SPARC :-)
All 3 gave the same result. I see just the two original versions. What is
strange,
too, is if I download them I get versions from back in September, which I am
assuming
are NOT the versions just posted last week.
Philip Restuccia
Philip Restuccia
Nortel Networks
pjr89@n...
>>(Netscape
>>back in
>>September.
>> Philip Restuccia
> system?
> Jim H
I see them also. One remote possibility is that his ISP is keeping
cached pages and feeding them to him instead of actually going to the
site. I have seen this with some smaller ISP's.
Just my .02
Dale Harwood [noparse][[/noparse] N4VFF ]
internet> dale@h...
ax.25> n4vff@n4vff.#cha.tn.usa.noam
#include <std_disclaimer.h>
> Hmmm ... perhaps you should go to that page again and manually refresh your
Tried that too, Jon. Forced both Netscapes to reload the page from the site.
Didn't bother trying with IE, since I had never used IE to access the site
in the first place.
This is very strange, I have to admit!
Thanks for all the suggestions, though. I've already tried everything that
everyone has suggested, to no avail. But I sure appreciate everyone's
suggestions!
Philip Restuccia
> -- Jon Williams
> pjr89@n... writes:
> > the
> > dated
Philip Restuccia
Nortel Networks
pjr89@n...
these
> >>(Netscape
> >>back in
> >>September.
plus
> >> Philip Restuccia
> > system?
> > Jim H
Well, I am trying to access the site from my work SPARC and PC. I work for
Nortel Networks (no jokes, please :-) and I *think* our ISP is Sprint. So
it's not really a smaller ISP; even if it's NOT Sprint, I doubt Nortel would
be using a smaller ISP.
Thanks for the suggestion though, Dale.
Philip Restuccia
> Just my .02
> internet> dale@h...
Philip Restuccia
Nortel Networks
pjr89@n...
http://www.parallaxinc.com/downloads/tokenizer/PBASIC_Tokenizer.sit
both of these
browsers
> > >(Netscape
the two,
files from
> > >back in
> > >September.
posting, plus
> > > Philip Restuccia
downloaded
browser cache
cached on your
> > system?
(Netscape 4.78)
to access the
as much as I
What is strange,
which I am assuming
> Philip Restuccia
> Philip Restuccia
> Nortel Networks
> pjr89@n...
Download File Name Description
318 KB PBASIC_Tokenizer.zip Suggested download for Windows developers.
318 KB PBASIC_Tokenizer.tar.gz Suggested download for Linux developers.
318 KB PBASIC_Tokenizer.sit Suggested download for Macintosh developers.
To be conscious that you are ignorant is a great step to knowledge.
-- Benjamin Disraeli
Original Message
your
site.
> in the first place.
suggestions!
this
with
> > > the
files
> > > dated
> of these
> > >(Netscape
> > >back in
> > >September.
> posting, plus
> > system?
>4.78)
>access the
>as I
>strange,
>am assuming
Maybe your provider is caching the page? Not to argue, but you can't
possibly see a different page than I see unless it's a problem with caching
either by your provider or in your browser.
Jim H
different tokenizer (the language has many differences compared to the BS2 and
above) and could not be included in the current tokenizer porting efforts.
--Jeff Martin
Engineering Manager
Original Message
> From: Octavio P Nogueira [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=pXSXacaeK9hMrGnHvJESwL_A6j8Ge_NvXtBcpv0kvuN0h93V3XgelQerJXmN_rLVPtDaydZW2LzpP9GS0EfSlEsrHQ]octaviopnogueira@u...[/url
> Sent: Monday, October 21, 2002 12:59 PM
> Subject: RES: [noparse][[/noparse]basicstamps] New PBASIC Tokenizer Released Today
> What about a tokenizer for BASIC Stamp 1?
> Octavio
Mensagem original
> De: pjr89@n... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=adBU0YyMI5_LdGhPVc1EZg972cZEOmmlkNIDykOVUdi4pzR5JsgvkQnqmh9m5NL8NtrfQq3HggIBClhCX8KF3g]pjr89@n...[/url
> Enviada em: segunda-feira, 21 de outubro de 2002 17:37
> Para: basicstamps@yahoogroups.com
> Assunto: Re: [noparse][[/noparse]basicstamps] New PBASIC Tokenizer Released Today
> Jeff Martin wrote:
> > Hi,
> (OS 9 and OS
> versions.
> structure
> should
> need to make a
> Tokenizer
> Linux and Mac)
> from:
> of the NEWS column.
these
(Netscape
back in
September.
plus
Philip Restuccia
Philip Restuccia
Nortel Networks
pjr89@n...
If the Mac download didn't show - maybe you need to refresh the page?
The cache wouldn't have to be very old to be out of date.
>page, with the
>contained files dated
> > of these
> > > >(Netscape
> > > >back in
> > > >September.
> > posting, plus
your
> > > system?
> >4.78)
> >access the
> >as I
> >strange,
> >am assuming
You are, of course, correct Jim. Since it's not being cached in any of the
browsers
I've tried, our ISP *must* be cacheing it.
Or ... at least they WERE ... I just tried it again, and FINALLY I can see all 3
files!
Thanks again to everyone who took the time to offer their help. I appreciate it!
Philip Restuccia
> Jim H
Philip Restuccia
Nortel Networks
pjr89@n...
> Try getting the file directly.
No longer necessary, dirt939. Apparently the page was being cached by our ISP
(seemed to have been cached for awhile ... I first downloaded the files last
Wednesday!). I just tried again, and FINALLY see all 3 files.
Thank you for taking the time to offer a suggestion, though; I appreciate it!
Philip Restuccia
> both of these
> browsers
> > > >(Netscape
> the two,
> files from
> > > >back in
> > > >September.
> posting, plus
> > > > Philip Restuccia
> downloaded
> browser cache
> cached on your
> > > system?
> (Netscape 4.78)
> to access the
> as much as I
> What is strange,
> which I am assuming
> > Philip Restuccia
> > Philip Restuccia
> > Nortel Networks
> > pjr89@n...
Philip Restuccia
Nortel Networks
pjr89@n...
