more help!
> > alright, I'm on to stepper motors, I have a uni-polar 6 wired stepper
>motor,
> > I understand I need to run my stamp pin through a transistor in order to
> > increase the current, but I'm not sure of the setup, like I don't know
>what
> > wires to connect to on my motor, I know that the 2 reds are common and
>the
> > colours of the different stages, but I don't the know where I connect
>the
> > collector of the transistor, that kinda stuff!
I have to use the transistor way, I cannot use stepper IC's cause this is a
lab for school, and the point is to be able to use it with transistors!
> > so any info would be great!
> > Thanks alot Brad
> > _________________________________________________________________
> > Unlimited Internet access for only $21.95/month. Try MSN!
> > http://resourcecenter.msn.com/access/plans/2monthsfree.asp
> > To UNSUBSCRIBE, just send mail to:
> > basicstamps-unsubscribe@yahoogroups.com
> > from the same email address that you subscribed. Text in the Subject
>and
>Body of the message will be ignored.
> > Your use of Yahoo! Groups is subject to
>http://docs.yahoo.com/info/terms/
>from the same email address that you subscribed. Text in the Subject and
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Get faster connections·-- switch to·MSN Internet Access!
http://resourcecenter.msn.com/access/plans/default.asp
>motor,
>what
>the
>the
> > Thanks alot Brad
>and
a high current darlington transistor array. so they
are still transistors, just in a dip format. i see
where your lab is going, i just wanted to clarify that
point. do a google search for "how to drive a
transistor" or something of that variety, there are
tons of links, or your EE text books should have many
examples. here is a nice link, should tell all u need
to know:
http://hyperphysics.phy-astr.gsu.edu/hbase/electronic/transwitch.html
here is a stepper example using the BS1 that gives a
brief explanation of the "how/why" rather than just
the code, it is application note #6. i havent played
with steppers much, perhaps someone else has info to
share.
http://www.parallaxinc.com/downloads/Documentation/Basic%20Stamps/BASIC%20Stamp%\
201%20App%20Notes%20v1.9.pdf
hope that helps you out,
ross
> > > Thanks alot Brad
> Try MSN!
> Text in the Subject
> >and
> Access!
> Text in the Subject and Body of the message will be
> ignored.
Do you Yahoo!?
Faith Hill - Exclusive Performances, Videos & More
http://faith.yahoo.com
The basic stamp can provide stepper motor drive can't it?
If so then driving the stepper motor from the stamp would require a device
(circuit) to provide increased current. This is why I have suggested the
ULN2803, as it is a damn simple device providing a high current output, that
is simple to use, ie requiring power, ground and an output from the stamp.
What do you think?
Dwain.
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Friday, October 18, 2002 12:45 PM
Subject: Re: [noparse][[/noparse]basicstamps] more help!
> that chip (ULN2803)is NOT a stepper driver chip, it is
> to know:
> share.
amp%201%20App%20Notes%20v1.9.pdf
> ross
> > > > Thanks alot Brad
> > Try MSN!
> > Text in the Subject
> > >and
> > Get faster connections -- switch to MSN Internet
> > Access!
> > ignored.
> Do you Yahoo!?
the same chip, if teh stepper were sized correctly to
its current supply abilities. i was merely pointing
out to Brad Hughson, the originator of teh question,
that the ULN2803 is not a stepper driver IC like that
made by Elab, check out www.elabinc.com and the
EDE1200 or 1204.
for his lab, he has to just use regular transistors
like the 2n222 or 2n3904, that was his question on how
to bias them. i hope that clarifies where i was
coming from.
ross
--- "Dwain J. Hill" <asdfghjk@b...> wrote:
> Klutch,
> can't it?
> What do you think?
> Regards,
> Dwain.
Original Message
> From: "Klutch" <klutch66@y...>
> it is
> they
> see
> that
> are
> many
> need
> > to know:
> a
> just
> played
> to
> > share.
> > ross
> use
> > > > > Thanks alot Brad
> $21.95/month.
> > > Try MSN!
> subscribed.
> > > Text in the Subject
> > > >and
> subscribed.
> > > Access!
> be
> > > ignored.
> > Do you Yahoo!?
> ignored.
Do you Yahoo!?
