more help! — Parallax Forums
more help!
edited 2002-10-18 17:56 in General Discussion
> > alright, I'm on to stepper motors, I have a uni-polar 6 wired stepper
>motor,
> > I understand I need to run my stamp pin through a transistor in order to
> > increase the current, but I'm not sure of the setup, like I don't know
>what
> > wires to connect to on my motor, I know that the 2 reds are common and
>the
> > colours of the different stages, but I don't the know where I connect
>the
> > collector of the transistor, that kinda stuff!
I have to use the transistor way, I cannot use stepper IC's cause this is a
lab for school, and the point is to be able to use it with transistors!
> > so any info would be great!
> > Thanks alot Brad
> > _________________________________________________________________
> > Unlimited Internet access for only $21.95/month. Try MSN!
> > http://resourcecenter.msn.com/access/plans/2monthsfree.asp
> > To UNSUBSCRIBE, just send mail to:
> > basicstamps-unsubscribe@yahoogroups.com
> > from the same email address that you subscribed. Text in the Subject
>and
>Body of the message will be ignored.
> > Your use of Yahoo! Groups is subject to
>http://docs.yahoo.com/info/terms/
>from the same email address that you subscribed. Text in the Subject and
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Get faster connections·-- switch to·MSN Internet Access!
http://resourcecenter.msn.com/access/plans/default.asp
    edited 2002-10-18 03:45
    that chip (ULN2803)is NOT a stepper driver chip, it is
    a high current darlington transistor array. so they
    are still transistors, just in a dip format. i see
    where your lab is going, i just wanted to clarify that
    point. do a google search for "how to drive a
    transistor" or something of that variety, there are
    tons of links, or your EE text books should have many
    examples. here is a nice link, should tell all u need
    to know:
    http://hyperphysics.phy-astr.gsu.edu/hbase/electronic/transwitch.html
    here is a stepper example using the BS1 that gives a
    brief explanation of the "how/why" rather than just
    the code, it is application note #6. i havent played
    with steppers much, perhaps someone else has info to
    share.
    http://www.parallaxinc.com/downloads/Documentation/Basic%20Stamps/BASIC%20Stamp%\
    201%20App%20Notes%20v1.9.pdf
    hope that helps you out,
    ross
    > > > Thanks alot Brad
    > Try MSN!
    > Text in the Subject
    > >and
    > Access!
    > Text in the Subject and Body of the message will be
    > ignored.
    Do you Yahoo!?
    Faith Hill - Exclusive Performances, Videos & More
    http://faith.yahoo.com
    edited 2002-10-18 03:53
    Klutch,
    The basic stamp can provide stepper motor drive can't it?
    If so then driving the stepper motor from the stamp would require a device
    (circuit) to provide increased current. This is why I have suggested the
    ULN2803, as it is a damn simple device providing a high current output, that
    is simple to use, ie requiring power, ground and an output from the stamp.
    What do you think?
    Dwain.
    Sent: Friday, October 18, 2002 12:45 PM
    Subject: Re: [noparse][[/noparse]basicstamps] more help!
    > to know:
    > share.
    amp%201%20App%20Notes%20v1.9.pdf
    > ross
    > > > > Thanks alot Brad
    > > Try MSN!
    > > Text in the Subject
    > > >and
    > > Get faster connections -- switch to MSN Internet
    > > Access!
    > > ignored.
    > Do you Yahoo!?
    yes, i could not agree more, and i would probably use
    the same chip, if teh stepper were sized correctly to
    its current supply abilities. i was merely pointing
    out to Brad Hughson, the originator of teh question,
    that the ULN2803 is not a stepper driver IC like that
    made by Elab, check out www.elabinc.com and the
    EDE1200 or 1204.
    for his lab, he has to just use regular transistors
    like the 2n222 or 2n3904, that was his question on how
    to bias them. i hope that clarifies where i was
    coming from.
    ross
    --- "Dwain J. Hill" <asdfghjk@b...> wrote:
    > Klutch,
    > can't it?
    > What do you think?
    > Regards,
    > Dwain.
    > From: "Klutch" <klutch66@y...>
    > it is
    > they
    > see
    > that
    > are
    > many
    > need
    > > to know:
    > a
    > just
    > played
    > to
    > > share.
    > > ross
    > use
    > > > > > Thanks alot Brad
    > $21.95/month.
    > > > Try MSN!
    > subscribed.
    > > > Text in the Subject
    > > > >and
    > subscribed.
    > > > Access!
    > be
    > > > ignored.
    > > Do you Yahoo!?
    > ignored.
    Do you Yahoo!?
