tabrobotkit
Hello,
Bought me today an tabrobotkit.
Does someone have exp.(good or bad) with this thing??
I have an BS2p ,can I use it to program or do I have to by an BS2?
Johan
Johan
I'm just repeating what I said in my previous email to you for the benefit
of everybody on the list.
You should be able to use a BS2p instead of the BS2. When I wrote the
software, I tested it with a BS2sx and BS2e - so there shouldn't be any
reason why the BS2p doesn't work other than you may have to change some of
the template software based on exactly how the BS2p works.
I don't have the BASIC Stamp databook in front of me, but the only concern I
would have is current consumption - the BS2p shouldn't require more current
than the BS2 or else you will find that the robot's batteries will not run
as long as expected.
myke
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Wednesday, October 09, 2002 1:51 PM
Subject: [noparse][[/noparse]basicstamps] tabrobotkit
> Hello,
> Johan
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
the BS2. You can expect shorter battery life with the BS2p versus the BS2.
-- Jon Williams
-- Parallax
In a message dated 10/9/02 4:19:04 PM Central Daylight Time, myke@p...
writes:
> Hello,
> thing??
I got it. It's front skid gets stuck in the
grout lines between my tiles. Other than that
it works fine. You need a flat surface to
run it on.
I just bought the BS-2 for $35 to get the discount.
Now I got two to network...
> to by an BS2?
Like the comments before It should work, but
higher current draw.
> Johan
Dave La Rosa
16. A snooze button is a poor substitute for no alarm
clock at all.
-- Top 20 Sayings On Office Inspirational Posters
__________________________________________________
Do you Yahoo!?
Faith Hill - Exclusive Performances, Videos & More
http://faith.yahoo.com
some traction. That solved a number of problems for me.
James
On Wed, 9 Oct 2002 17:18:07 -0700 (PDT) Dave La <dalgroups@y...> wrote:
> --- Johan wrote:
> > Hello,
> > thing??
> run it on.
> discount.
> I have
> > to by an BS2?
> > Johan
> Dave La Rosa
> alarm
> clock at all.
> Posters
> Do you Yahoo!?
> More
> subscribed. Text in the Subject and Body of
wrote:
> I found that cutting triangular grooves with an
> exacto knife gives the wheels
> me.
My problem is not with the wheels it is
with the front nose skid. The grout is
roughly about 1/16" below the surface of
the tile. I don't think the extra traction
would help. The robot just follows the grout
lines forever
I thinking of removing the wheels and adding
on tank treads. TAIKO (sp) has a set for
$15 but is only one motor drive instead
of two. So a little mechanical engineering
is needed.
> James
> > --- Johan wrote:
> > > Hello,
> > > thing??
> > run it on.
> > discount.
> > I have
> > > to by an BS2?
> > > Johan
> > Dave La Rosa
> > alarm
> > clock at all.
> > Posters
> > Do you Yahoo!?
> > More
> Text in the Subject and Body of the message will be
> ignored.
"These acts were intended to frighten us, but they
have failed. Terrorist acts can shake the
foundations of our biggest buildings but
cannot touch the foundation of America." --
President George W. Bush, address to the nation;
about Sep. 11, 2001 terrorist attack.
Do you Yahoo!?
Original Message
Sent: Friday, October 11, 2002 1:18 PM
Subject: Re: [noparse][[/noparse]basicstamps] tabrobotkit
> --- James Waldron <jamesrwaldron@e...>
> > me.
> lines forever
> is needed.
As you said, the problem is not with the wheels, but with the "front nose".
Just replace that acorn nut with an adhesive teflon "furniture mover". They
cost $3 for a set of four, available at your local supermarket or hardware
store.. My robot now moves over carpets and tiles with ease. The teflon
disks are just over one inch in diameter, and stick nicely to the bottom
front of the robot board. Remove the acorn nut, and stick on a teflon disk.
-CK
