tabrobotkit — Parallax Forums
tabrobotkit
edited 2002-10-12 02:47 in General Discussion
Hello,
Bought me today an tabrobotkit.
Does someone have exp.(good or bad) with this thing??
I have an BS2p ,can I use it to program or do I have to by an BS2?
Johan
    edited 2002-10-09 22:16
    Hi Johan,
    I'm just repeating what I said in my previous email to you for the benefit
    of everybody on the list.
    You should be able to use a BS2p instead of the BS2. When I wrote the
    software, I tested it with a BS2sx and BS2e - so there shouldn't be any
    reason why the BS2p doesn't work other than you may have to change some of
    the template software based on exactly how the BS2p works.
    I don't have the BASIC Stamp databook in front of me, but the only concern I
    would have is current consumption - the BS2p shouldn't require more current
    than the BS2 or else you will find that the robot's batteries will not run
    as long as expected.
    myke
    Sent: Wednesday, October 09, 2002 1:51 PM
    Subject: [noparse][[/noparse]basicstamps] tabrobotkit
    > Hello,
    > Johan
    edited 2002-10-10 00:30
    The BS2p runs significantly faster and, therefore, draws more current than
    the BS2. You can expect shorter battery life with the BS2p versus the BS2.
    -- Jon Williams
    -- Parallax
    In a message dated 10/9/02 4:19:04 PM Central Daylight Time, myke@p...
    writes:
    edited 2002-10-10 01:18
    --- Johan <johan.v@p...> wrote:
    > Hello,
    > thing??
    I got it. It's front skid gets stuck in the
    grout lines between my tiles. Other than that
    it works fine. You need a flat surface to
    run it on.
    I just bought the BS-2 for $35 to get the discount.
    Now I got two to network...
    > to by an BS2?
    Like the comments before It should work, but
    higher current draw.
    > Johan
    Dave La Rosa
    16. A snooze button is a poor substitute for no alarm
    clock at all.
    -- Top 20 Sayings On Office Inspirational Posters
    __________________________________________________
    Do you Yahoo!?
    Faith Hill - Exclusive Performances, Videos & More
    http://faith.yahoo.com
    edited 2002-10-10 13:36
    I found that cutting triangular grooves with an exacto knife gives the wheels
    some traction. That solved a number of problems for me.
    James
    On Wed, 9 Oct 2002 17:18:07 -0700 (PDT) Dave La <dalgroups@y...> wrote:
    > --- Johan wrote:
    > > Hello,
    > > thing??
    > run it on.
    > discount.
    > I have
    > > to by an BS2?
    > > Johan
    > Dave La Rosa
    > alarm
    > clock at all.
    > Posters
    > Do you Yahoo!?
    > More
    > subscribed. Text in the Subject and Body of
    edited 2002-10-11 21:18
    --- James Waldron <jamesrwaldron@e...>
    > me.
    My problem is not with the wheels it is
    with the front nose skid. The grout is
    roughly about 1/16" below the surface of
    the tile. I don't think the extra traction
    would help. The robot just follows the grout
    lines forever
    I thinking of removing the wheels and adding
    on tank treads. TAIKO (sp) has a set for
    $15 but is only one motor drive instead
    of two. So a little mechanical engineering
    is needed.
    > James
    > > --- Johan wrote:
    > > > Hello,
    > > > thing??
    > > run it on.
    > > discount.
    > > I have
    > > > to by an BS2?
    > > > Johan
    > > Dave La Rosa
    > > alarm
    > > clock at all.
    > > Posters
    > > Do you Yahoo!?
    > > More
    > Text in the Subject and Body of the message will be
    > ignored.
    "These acts were intended to frighten us, but they
    have failed. Terrorist acts can shake the
    foundations of our biggest buildings but
    cannot touch the foundation of America." --
    President George W. Bush, address to the nation;
    about Sep. 11, 2001 terrorist attack.
    Do you Yahoo!?
    Sent: Friday, October 11, 2002 1:18 PM
    Subject: Re: [noparse][[/noparse]basicstamps] tabrobotkit
    > > me.
    > lines forever
    > is needed.
    As you said, the problem is not with the wheels, but with the "front nose".
    Just replace that acorn nut with an adhesive teflon "furniture mover". They
    cost $3 for a set of four, available at your local supermarket or hardware
    store.. My robot now moves over carpets and tiles with ease. The teflon
    disks are just over one inch in diameter, and stick nicely to the bottom
    front of the robot board. Remove the acorn nut, and stick on a teflon disk.
    -CK
