Potpourri
Did you know you can use a Darlington 2003 or 2803 for an inverting level
converter ? 5 to 30VDC input, 5 to 50 VDC output. All it takes is a 4.7K
resistor from the output power to the collector pin.
Sid Weaver
W4EKQ
Port Richey, FL
Sid Weaver
W4EKQ
Port Richey, FL
Original Message
From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=wwhX8rxXScFwKTxndyEE5r1m1-WFBLMjbrXdLIbpUKCuHRB7iVdtoKbmVjMDK8L6k5yLmgDN]Newzed@a...[/url
Sent: Tuesday, October 08, 2002 6:48 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Potpourri
Sid Weaver
W4EKQ
Port Richey, FL
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
porter.sadler@s... writes:
> I did not understand that can you elaborate
For instance - 12VDC to pin 10 of a 2803 and Gnd to pin 9. Tie pin 18 to
5VDC via a 4.7K. With no input signal on pin 1 the voltage at pin 18 is
5VDC. Apply 12VDC to pin 1, it turns on the Darlington, and pin 18 goes low.
You have now converted a 12VDC input signal to a 5VDC output signal,
inverted of course. You could use 24VDC instead of 5VDC on the output and
converted the level from 12 to 24VDC. Or you could put 5VDC on pin 10, 12VDC
on pin 18, and convert a 5 volt level to a 12 volt level.
Understood?
Sid Weaver
W4EKQ
Port Richey, FL
Original Message
From: Sadler Porter [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=D1tI2U_RHIxuuXCA4zJ6ijYtwvbhLdBs1j2ZOtBRUXNvhPXNplRjPe8bHoPly8ReZrQLgqvuKfUmvZlSpknIxsEumpk]porter.sadler@s...[/url
Sent: Wednesday, October 09, 2002 1:31 PM
Subject: RE: [noparse][[/noparse]basicstamps] Potpourri
I did not understand that can you elaborate.
Original Message
From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=NI_rf6VyPu-FPdp39FXP4ei9q7vkG_ifdzYb1kitku54MYJlrX4p0uO2mz8n7RNI9WBlsNUa4m1i]Newzed@a...[/url
level
4.7K
Sid Weaver
W4EKQ
Port Richey, FL
and
and Body of the message will be ignored.
Are you saying that I could make up a 5 to 12 volt step up using a 2003?
I have an application where I need a 12v supply to an encoder, at requires
14mA at 12v. Is this possible, and if so, can you give more details.
Chris
Original Message
To: <:basic@yahoogroups.com
Sent: Wednesday, October 09, 2002 6:48 AM
> Sid Weaver
> W4EKQ
> Port Richey, FL
fuel@b... writes:
Good evening, Chris.
Apply 5VDC to pin 8 of the 2003. Attach a 4.7K to each output pin and tie
them all to 12VDC. The output collector pin at the bottom of the resistor is
your inverted 12VDC signal. A high on the input gives a low on the output
and vice versa.
Sid
Essendon, a suburb of Melbourne. Great country!
Sid
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Monday, October 14, 2002 7:27 AM
Subject: Re: [noparse][[/noparse]basicstamps] Potpourri
> By the way, whereabouts in Australia do you live. A long time ago I lived
in
> Sid
work in the Panama Canal. Saludos!
Original Message
From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=xBllvZPp3M5UnykjVKl71mH00Jm75atyNfpvBO-sIrguM90opBcdTrjFagovrCyribzjO8rQ9bY]Newzed@a...[/url
Sent: Sunday, October 13, 2002 4:28 PM
in
Sid
